我的文章中作了一个标样,但是不知道标准号应该怎样写,是写GSBZ 50009—88(2)吗?那么下面的0270109是什么意思呢?请大家帮帮忙吧,谢谢了!
【由于该附件或图片违规,已被版主删除】 中华人民共和国国家标准
GSBZ 50009—88(2)
NATIONAL CERTIFIED
REFERENCE MATERIALS OF P. R. CHINA
环境标准样品证书
CERTIFICATE OF ENVIRONMENTAL
REFERENCE MATERIAL
铅 Pb
中 国 北 京
国家环境保护总局标准样品研究所
INSTITUTE FOR REFERENCE MATERIALS OF SEPA
BEIJING, CHINA
环境标准样品主要用于环境监测及分析测试中的质量保证和质量控制,亦可用于分析仪器校正、分析方法比对和分析技术仲裁。
本标准样品采用高纯试剂在超净间中准确配制,分装于20毫升安瓿内,经均匀性检验合格。其标准值和不确定度是由多家实验室用
原子吸收法进行分析测定,并经数理统计处理后确定的。
本标准样品应在阴凉处保存。
临用时割开安瓿,用10毫升干燥洁净移液管从安瓿中准确移取浓样10 毫升于250 毫升容量瓶中,用1%硝酸定容。稀释后标准样品溶液浓度见下表:
The Environmental Reference Materials (ERMs) are primarily used in quality assurance and quality control in the process of environmental monitoring and analysis, and it can also be used in analytical instrument correction, analytical method contrast and analytical technology arbitration.
This ERM was prepared in super-clean lab with high pure reagents and sub-packed in 20ml ampoules. No significant differences in concentration among sub-samples were found. The certified value and uncertainty were based on the analytical results of eight labs by
AAS method.
This ERM should be stored at a dark and cool place.
When you use this ERM, please carefully break open the ampoule at the neck and pipette 10 ml from the ampoule into 250 ml volumetric flask and bring to volume by 1% HNO3 solution.
The concentration of the diluted solution is as following:
铅 Pb 0270109
成 分 标准值(mg/L) 不确定度(mg/L)
Component Certified value Uncertainty
Pb 1.20 0.07
有效期到 2005 年 12 月
The expiration date is up to Dec.2005.
