主题:【资料】电导测试池(Conductivity Cell) 的技术资料
浏览0 回复0 电梯直达
老鱼
型号:CON-H
技术参数
控温范围: 0-1200 C°
样品尺寸 15 mm 直径 6 mm 最大厚度
接触盘 白金圆盘, 弹簧进样
材料构成 氧化铝 99.5 % 白金 99.5 %
接触压力 最大到 15 N (可调)
Gas compatibility Any reducing or oxidizing gas compatible with fused silica and allumina
Gas connections Pipe holder in/out for 3 mm inner dia piping (viton recommended)
Gas tightness Viton O-rings
Orientation Vertical
ELECTRICAL FEATURES
Connections BNC
Measuring configuration 2-wires connections + wire compensation
Residual resistance <5 mOhm
Effective wire resistance < 3 Ohm @ 25 C°
Maximum current capability 2 A
OPTIONS
Gas Partial pressure of oxygen sensor mounted near the sample, vacuum option
Mechanical pressure Variable pressure with mechanical stop for melting/softening samples
Electrical connections Additional wiring for sensing partial voltages
Mechanical Various mechanical measures with interfaceable instruments (expansion measures, melting/softening)
Sample shapes Larger / thicker samples
主要特点
Measuring cell from Material Mates, based on more than two decades of experience in difficult measuring tasks, easily fit very different sample shapes within the spring loaded contact plates.
Simple, repeatable measurements can then be performed on a wide range of impedances, thanks to a “wiring compensating technique” that takes care of wiring impedance without the hassle of sensing geometry on a true 4-wires configuration.
With a maximum temperature of 1200 C°and a true “flow through“ gas path for controlled atmosphere operation the cell is suited for conductivity characterization at gas/temperature variation or high frequency EIS measures on grain to grain boundary and bulk properties.
The measuring head has low electrical noise and good frequency behavior thanks to the short length design and the accurate shielding.
