主题:【求助】大家看看这是什么色谱柱?
linsun007
Column conditions : Carbopak B (60/80mesh) coated with 1% SP-1000 packed in a 6 ft by 0.1 in.ID glass column with helium carrier gas at 30mL/min flow rate. Column temperature held at 45℃for three minutes , then programmed at 8℃/min. to 220℃ and held for 15 minutes.
它这里面讲的色谱柱,符合哪种具体型号?
〓疯子哥〓
Unicarbon B-1000
主要是用于石化分析专用柱
Last edit by madprodigy
