原文由 afbunny 发表:
建议还是把上下文都传过来,这样断章取义太恐怖了!我不知道滴定要单点校准什么啊?标准曲线一般都做2个点以上,而找拐点是不需要校准的呀,传传上下文,我们都学习学习。
原段落如下:Sample calculations----
Titrimetric analyses are often performed with single-point standardization.standardization of a base titrant solution,used to determine the amount of acid in a sample,is often performed using a known,dry weight of potassium hydrogen phthalate(KHP)as a standard.There is one proton,or equivalent,per mole of KHP.
打字累!呵呵...各位辛苦了
