主题:【求助】ICP-MS可以磷酸进样吗?
浏览0 回复17 电梯直达
a_lei82
如题,我想问一下,ICP-MS可以不可以磷酸介质进样,磷酸浓度低于30%可以直接进吗?
您可能想找: ICP-MS电感耦合等离子体质谱 询底价
fangzhen0221
highspeed_v
磷酸粘性很大,30%浓度太高了,可以的话多稀释一些
歪门邪道读鸟书
原文由 a_lei82 发表:
浓磷酸至少要稀释100倍才能进ICPMS
zsm79
a_lei82
wolf2011
原文由 a_lei82 发表:
是测定磷酸中的杂质,大家谁知道怎么处理吗?
对85酸应稀释80-100倍后进样,可试试标准加入法测其中的杂质。
may0105
原文由 a_lei82 发表:
What level of acid concentration can be used in ICP?
Below mentioned list gives an overview of the acidic compounds level that can be used in ICP . These are general recommendation and incase of any specific compounds refer to Agilent
Nitric acid: Up to 40%. This is most suitable for ICP-MS analysis.
Hydrochloric acid: Up to 18%. However, avoid using if possible. As chlorine compounds may cause blockages, if used, evaporating the hydrochloric acid is recommended. However, care is required as metallic chlorides may also volatize.
Hydrofluoric acid: Up to 30% if a hydrofluoric acid resistant kit is used.
Sulphuric acid: Up to 1%. Use is strongly discouraged.
Phosphoric acid: Up to 0.1%. Use is strongly discouraged.
Nitrohydrochloric acid: Dilute by 3 to 10 times. Treating in the same way as hydrochloric acid is recommended.
renjianshenxian
nan5460
chauchylan
若用磷酸进样的话,则标样也应是以磷酸为介质的,不过直接进样
可进行半定量分析….根据样品的特性,具体问题具体分析…..
