Spike: Enter up to 4 alphanumeric characters for the spike solution. Enter the concentration of the spike solution to the number of decimal places entered in the method’s Decimal field. SmartChem will calculate the “actual” spike concentration of the spiked sample. The calculated spike concentration will be reported on the method printout page.
Aspk= (Ca*Va)/Vs Cv= (Vs-Va)/Vs
%Recovery= { [Cm-(Cv*Cs)]/Aspk} * 100
Cs= Concentration of Sample (Determined)
Cm= Concentration of Sample + Spike (Determined)
Ca= Spike Concentration Vs= Sample Volume Va= Spike Volume Aspk= Actual Spike
Cv= Volume Correction Factor
Spike(添量试样): 输入4个字符以内命名Spike(添量试样),输入其浓度,浓度可以精确至的小数点位数在方法中已经设置过。SmartChem将根据spiked sample的浓度计算实际的spike浓度,进而计算其回收率。具体计算方式如下,计算结果将在报告中显示:
Aspk = (Ca*Va)/Vs
Cv= (Vs-Va)/Vs
%Recovery回收率= { [Cm-(Cv*Cs)]/Aspk} * 100
Cs= 已知样品浓度
Cm= 样品+已知Spike 总浓度
Ca= Spike 浓度
Vs= 样品体积
Va= Spike 体积
Aspk=实际Spike浓度Actual Spike
Cv= 体积校正因子
原文由 imokfe 发表:
我也对Spike solution是什么意思很迷惑,下面是USP方法的原文,希望对大家对这个词汇的意思能有所启发。
D. Sample Fortification and Mixed Standard Preparation
A Mixed Standard Spiking solution is prepared by mixing equal portions of the two stock standard solutions to create a solution which is 5.0 mg/mL in each analyte.
Spike Preparation
Weigh a 1.0 g portion of sample into a 15-mL centrifuge tube. A previously analyzed, representative example of the product which was found to be uncontaminated with the targets may be used.
Alternatively, select one of the samples which is about to be analyzed and spike a portion of it. This would have to be repeated with a different sample if it turns out that analysis of this sample without fortification gave evidence of contamination.
Add 200 μL of the Mixed Standard Spiking solution directly to the representative uncontaminated sample and proceed with the method. The spike must be observed to provide a basis for declaring that samples which provide signals below a certain threshold contain less than 1.0 mg/g of either target.
原文由 suxue 发表:
原文由 shaweinan 发表:
原文由 gongxh 发表:
谢谢各位老师的回复!
原文是这样的:
1. pipet diluent + modifier 1 + spike + sample/std
2. If spike outside of limit, also reanalyze sample
PE工程师的说法肯定是错误的。依我个人理解好象应该是这样:
1.吸量管稀释液+基体改进剂1+加标量+试样或标准
2. 如果加标量超出限定范围,就重新分析试样
此举的目的是通过测定回收率来验证方法的准确性。
同意
