原文由 ruojun 发表:
楼主自己先翻译一下吧,然后大家帮你修改
好吧.
Dissolve 40.0 g of sample in carbon-dioxide free water. Allow to cool. Transfer this solution to a 1000ml volumetric flask and dilute to mark with the same water. Lable the solution as solution A. Pipet the solution A 20ml to a 500ml volumetric flask and dilute to the mark with the same water. Further pipet 20ml to a 100ml beaker, add 1 drop of methyl red indicator, then add acetic acid until the solution remains light-red. After heating the solution to 40ºC, 8-9ml of 0.1mol/L sodium tetraphenylborate -ethanol solution is dropwise added with agitating in 5 minutes. After addition, allow to stand for 10 minutes. Filter the mixture with a G4 glass crucible previously dried in a 115-125ºC oven until a constant weight was obtained. Wash the filter cake 8-10 times with each 5-ml potassium tetraphenylboron saturated solution. Then wash the filter cake once with 2ml of anhydrous ethanol. Dry the crucible in a 115-125ºC oven until a constant weight obtained.
