耶拿公司的HPT技术可以 High Power Tube: Sensitivity in flame technique can be increased for volatile elements e. g. Cd or Pb using high power tube burner head. High power burner head is a 50 mm standard burner equipped with a swivelling quartz tube above the burner slit. Improvement in sensitivity for Pb and Cd using HPT burner (0.25 ppm Cd, Pb) Values in Abs Element 50 mm 100 mm HPT
