原文由 franks8 发表:原文由 xuhaihong1001 发表:
The only options are to make sure the inlet liner is clean and silanized. The customer may try removing up to 1 meter of the column from the injection side. Last - simply re-condition the column thermally as if it were brand new.
唯一的选择是保证进口的洁净与硅烷化。用户可以尝试从进样面移除最多1米的柱体。最后,简单的按要求重新对柱体进行热处理...
