主题:【分享】常用塑料英语缩略语
迷失的精灵
ABA  Acrylonitrile-butadiene-acrylate  丙烯腈/丁二烯/丙烯酸酯共聚物
ABS  Acrylonitrile-butadiene-styrene  丙烯腈/丁二烯/苯乙烯共聚物
AES  Acrylonitrile-ethylene-styrene    丙烯腈/乙烯/苯乙烯共聚物
AMMA Acrylonitrile/methyl Methacrylate 丙烯腈/甲基丙烯酸甲酯共聚物
ARP  Aromatic polyester                聚芳香酯
AS  Acrylonitrile-styrene resin      丙烯腈-苯乙烯树脂
ASA  Acrylonitrile-styrene-acrylate    丙烯腈/苯乙烯/丙烯酸酯共聚物
CA  Cellulose acetate                醋酸纤维塑料
CAB  Cellulose acetate butyrate        醋酸-丁酸纤维素塑料
CAP  Cellulose acetate propionate      醋酸-丙酸纤维素
CE  Cellulose plastics, general      通用纤维素塑料
CF  Cresol-formaldehyde              甲酚-甲醛树脂
CMC  Carboxymethyl cellulose          羧甲基纤维素
CN  Cellulose nitrate                硝酸纤维素
CP  Cellulose propionate              丙酸纤维素
CPE  Chlorinated polyethylene          氯化聚乙烯
CPVC Chlorinated poly(vinyl chloride)  氯化聚氯乙烯
CS  Casein                            酪蛋白
CTA  Cellulose triacetate              三醋酸纤维素
EC  Ethyl cellulose                  乙烷纤维素
EMA  Ethylene/methacrylic acid        乙烯/甲基丙烯酸共聚物
EP  Epoxy, epoxide                    环氧树脂
EPD  Ethylene-propylene-diene          乙烯-丙烯-二烯三元共聚物
EPM  Ethylene-propylene polymer        乙烯-丙烯共聚物
EPS  Expanded polystyrene              发泡聚苯乙烯
ETFE Ethylene-tetrafluoroethylene      乙烯-四氟乙烯共聚物
EVA  Ethylene/vinyl acetate            乙烯-醋酸乙烯共聚物
EVAL Ethylene-vinyl alcohol            乙烯-乙烯醇共聚物
FEP  Perfluoro(ethylene-propylene)    全氟(乙烯-丙烯)塑料
FF  Furan formaldehyde                呋喃甲醛
HDPE High-density polyethylene plastics高密度聚乙烯塑料
HIPS High impact polystyrene          高冲聚苯乙烯
IPS  Impact-resistant polystyrene      耐冲击聚苯乙烯
LCP  Liquid crystal polymer            液晶聚合物
LDPE Low-density polyethylene plastics 低密度聚乙烯塑料
LLDPE Linear low-density polyethylene  线性低密聚乙烯
LMDPE Linear medium-density polyethylene 线性中密聚乙烯
MBS  Methacrylate-butadiene-styrene    甲基丙烯酸-丁二烯-苯乙烯共聚物
MDPE Medium-density polyethylene      中密聚乙烯
MF  Melamine-formaldehyde resin      密胺-甲醛树脂
MPF  Melamine/phenol-formaldehyde      密胺/酚醛树脂
英文简称  英文全称  中文全称
PA    Polyamide (nylon) 聚酰胺(尼龙)
PAA  Poly(acrylic acid) 聚丙烯酸
PADC  Poly(allyl diglycol carbonate) 碳酸-二乙二醇酯• 烯丙醇酯树脂
PAE  Polyarylether 聚芳醚
PAEK  Polyaryletherketone 聚芳醚酮
PAI  Polyamide-imide 聚酰胺-酰亚胺
PAK  Polyester alkyd 聚酯树脂
PAN  Polyacrylonitrile 聚丙烯腈
PARA  Polyaryl amide 聚芳酰胺
PASU  Polyarylsulfone 聚芳砜
PAT  Polyarylate 聚芳酯
PAUR  Poly(ester urethane) 聚酯型聚氨酯
PB    Polybutene-1 聚丁烯-[1]
PBA  Poly(butyl acrylate) 聚丙烯酸丁酯
PBAN  Polybutadiene-acrylonitrile 聚丁二烯-丙烯腈
PBS  Polybutadiene-styrene 聚丁二烯-苯乙烯
PBT  Poly(butylene terephthalate) 聚对苯二酸丁二酯
PC    Polycarbonate 聚碳酸酯
PCTFE Polychlorotrifluoroethylene 聚氯三氟乙烯
PDAP  Poly(diallyl phthalate) 聚对苯二甲酸二烯丙酯
PE    Polyethylene 聚乙烯
PEBA  Polyether block amide 聚醚嵌段酰胺
PEBA  Thermoplastic elastomer polyether 聚酯热塑弹性体
PEEK  Polyetheretherketone 聚醚醚酮
PEI  Poly(etherimide) 聚醚酰亚胺
PEK  Polyether ketone 聚醚酮
PEO  Poly(ethylene oxide) 聚环氧乙烷
PES  Poly(ether sulfone) 聚醚砜
PET  Poly(ethylene terephthalate) 聚对苯二甲酸乙二酯
PETG  Poly(ethylene terephthalate) glycol 二醇类改性PET
PEUR  Poly(ether urethane) 聚醚型聚氨酯
PF    Phenol-formaldehyde resin 酚醛树脂
PFA  Perfluoro(alkoxy alkane) 全氟烷氧基树脂
PFF  Phenol-furfural resin 酚呋喃树脂
PI    Polyimide 聚酰亚胺
PIB  Polyisobutylene 聚异丁烯
PISU  Polyimidesulfone 聚酰亚胺砜
PMCA  Poly(methyl-alpha-chloroacrylate) 聚α-氯代丙烯酸甲酯
PMMA  Poly(methyl methacrylate) 聚甲基丙烯酸甲酯
PMP  Poly(4-methylpentene-1) 聚4-甲基戊烯-1
PMS  Poly(alpha-methylstyrene) 聚α-甲基苯乙烯
POM  Polyoxymethylene, polyacetal 聚甲醛
PP    Polypropylene 聚丙烯
PPA  Polyphthalamide 聚邻苯二甲酰胺
PPE  Poly(phenylene ether) 聚苯醚
PPO  Poly(phenylene oxide) deprecated 聚苯醚
PPOX  Poly(propylene oxide) 聚环氧(丙)烷
PPS  Poly(phenylene sulfide) 聚苯硫醚
PPSU  Poly(phenylene sulfone) 聚苯砜
PS    Polystyrene 聚苯乙烯
PSU  Polysulfone 聚砜
PTFE  Polytetrafluoroethylene 聚四氟乙烯
PUR  Polyurethane 聚氨酯
PVAC  Poly(vinyl acetate) 聚醋酸乙烯
PVAL  Poly(vinyl alcohol) 聚乙烯醇
PVB  Poly(vinyl butyral) 聚乙烯醇缩丁醛
PVC  Poly(vinyl chloride) 聚氯乙烯
PVCA  Poly(vinyl chloride-acetate) 聚氯乙烯醋酸乙烯酯
PVDC  Poly(vinylidene chloride) 聚(偏二氯乙烯)
PVDF  Poly(vinylidene fluoride) 聚(偏二氟乙烯)
PVF  Poly(vinyl fluoride) 聚氟乙烯
PVFM  Poly(vinyl formal) 聚乙烯醇缩甲醛
PVK  Polyvinylcarbazole 聚乙烯咔唑
PVP  Polyvinylpyrrolidone 聚乙烯吡咯烷酮
S/MA  Styrene-maleic anhydride plastic 苯乙烯-马来酐塑料
SAN  Styrene-acrylonitrile plastic 苯乙烯-丙烯腈塑料
SB    Styrene-butadiene plastic 苯乙烯-丁二烯塑料
Si    Silicone plastics 有机硅塑料
SMS  Styrene/alpha-methylstyrene plastic 苯乙烯-α-甲基苯乙烯塑料
SP    Saturated polyester plastic 饱和聚酯塑料
SRP  Styrene-rubber plastics 聚苯乙烯橡胶改性塑料
TEEE  Thermoplastic Elastomer,Ether-Ester 醚酯型热塑弹性体
TEO  Thermoplastic Elastomer, Olefinic 聚烯烃热塑弹性体
TES  Thermoplastic Elastomer, Styrenic 苯乙烯热塑性弹性体
TPEL  Thermoplastic elastomer 热塑(性)弹性体
TPES  Thermoplastic polyester 热塑性聚酯
TPUR  Thermoplastic polyurethane 热塑性聚氨酯
TSUR  Thermoset polyurethane 热固聚氨酯
UF    Urea-formaldehyde resin 脲甲醛树脂
UHMWPE Ultra-high molecular weight PE 超高分子量聚乙烯
UP    Unsaturated polyester 不饱和聚酯
VCE  Vinyl chloride-ethylene resin 氯乙烯/乙烯树脂
VCEV  Vinyl chloride-ethylene-vinyl 氯乙烯/乙烯/醋酸乙烯共聚物
VCMA  Vinyl chloride-methyl acrylate 氯乙烯/丙烯酸甲酯共聚物
VCMMA Vinyl chloride-methylmethacrylate 氯乙烯/甲基丙烯酸甲酯共聚物
VCOA  Vinyl chloride-octyl acrylate resin 氯乙烯/丙烯酸辛酯树脂
VCVAC Vinyl chloride-vinyl acetate resin 氯乙烯/醋酸乙烯树脂
VCVDC Vinyl chloride-vinylidene chloride 氯乙烯/偏氯乙烯共聚物
雾非雾
