原文由 youjian000 发表:
New Connection...“新的连接...”
The New Connection... option causes a new Connection Details dialog to be displayed, so that a connection can easily be made to another K4000RC Server.
因为(点击/使用)“新的连接...”选项会(在显示屏上)显示一个新的“连接细节”对话框,所以可容易地连接到另外一个K4000RC服务器上。
Note that a K4000RC Viewer started in this way actually shares the same process as the K4000RC Viewer window from which it was started. The K4000RC Viewer process does not quit until both windows are closed. This may affect the behaviour of scripts which launch K4000RC Viewer.
需要注意的是:以这种方式启动的K4000RC浏览器,与从K4000RC浏览器视窗中启动,二者实际上共享相同的程序。只有当两个视窗都关闭后,才会退出K4000RC浏览器程序。这种方式可能会影响登录K4000RC浏览器的程序脚本的活动状态。
