原文由 dichangwei(dichangwei) 发表:
Desiccator
The instruction “in a desiccator” indicates use of a tightly closed container of suitable size and design that maintains an atmosphere of low moisture content by means of a suitable desiccant such as anhydrous calcium chloride, magnesium perchlorate, phosphorus pentoxide, or silica gel. See also section 8.220, Vacuum Desiccator
干燥器
“在干燥器中”指使用大小适当、能通过适当的干燥剂,如无水氯化钙、高氯酸镁、五氧化二磷或硅胶保持低湿度的密封容器。也可见于章节8.220,真空干燥器。
神奇了,这个帖子我6号回复过了呢
