主题:【资料】FDA今天公布的奶粉中三聚氰胺的LC/MS/MS分析方法
浏览0 回复4 电梯直达
恐龙
FDA-三聚氰胺分析方法-LC/MS/MS
FDA今天公布的奶粉中三聚氰胺的LC/MS/MS分析方法,采用zic-hilic的柱子,梯度洗脱,LC/MS/MS检测奶粉中的三聚氰胺和三聚氰酸。
您可能想找: 液质联用(LC-MS) 询底价
redyou
yuduoling
原文由 redyou 发表:
只是一个实验室论文吧。不像GC-MS那样是标准。
就是.
但是还是感谢楼主分享
mconcon
eugenec1
FDA 有言在先: "The Laboratory Information Bulletin is a communication from the Division of Field Science, ... In many cases, however, the report may not represent completed analytical work. The reader must assure, by appropriate validation procedures, that the reported methods or techniques are reliable and accurate for use as a regulatory method."
