主题:【求助】有做过土壤中的灭多威的吗?
浏览0 回复18 电梯直达
chenjp7758
正用GC做灭多威,用FPD-S检测器,色谱柱手头没有强极性柱,用RXT-17做的,检测条件:进样量1ul,进样口温度230 柱温180 检测器温度 203 柱流量 5ml/min ,发现没有峰,进标样也没出峰。是因为柱子的事么?
我在故我思
pingguwu
原文由 chenjp7758 发表:
还真没有看到用GC/FPD检测灭多威的,标准没有出峰,应该是检测器问题,再高浓度试一试,我们是用NPD\LC\GC/MS检测的.
2010/9/26 14:50:45 Last edit by zongguitang
乐果
广东海风
我在故我思
灭多威用GC测定的文献不是很多:
Direct gas chromatographic determination of methomyl (lannate®) with microcoulometric nitrogen detection
I. H. Williams
Abstract:
A microcoulometric method is described for the direct determination of nanogram amounts of methomyl (S-methyl-N-[(methylcarbamoyl)-oxy]thioacetimidate). An all-glass gas chromatographic system coupled to a microcoulometer with a nitrogen-specific cell was used. The column was packed with a mixture of 6% OV210 and 4% OV101 on Gas Chrom Q, as was the glass transfer tube which connected the chromatographic column to the pyrolysis furnace. Some loss occurred but response was linear from 125 to 20 ng and sensitivity was such that 20 ng of methomyl could be readily measured.
      http://www3.interscience.wiley.com/journal/112600458/abstract?CRETRY=1&SRETRY=0
Determination of methomyl by using 1-fluoro-2,4-dinitrobenzene reaction and gas-liquid chromatography
  http://pubs.acs.org/doi/abs/10.1021/jf60192a029
雾非雾
职业游民
戈壁明珠
楼主,适当升高柱温再试试。浓度高一些响应会好的多。
rzxjz
雾非雾
