相关物质HPLC检查中,关于梯度程序的:
1.as mobile phase at a flow rate of 1.5ml/min a
double isocratic programme using the following conditions. 红体字该如何理解?
2.The test is not valid unless the resolution between the peaks corresponding to verapamil and verapamil impurity I is at least 5.0 and verapamil impurity M elutes from the column.
这个5.0是什么意思?没看明白
3.Appearance of solution.是指澄清度吗?
多谢高手解答!
