主题:【求助】求纤维FTIR 分析相关英文论文
浏览0 回复0 电梯直达
myloveinwl
1、infrared spectroscopic analysis of crystallization in poly(ethylene naphthalte). polym.Eng.Sci,1999,81:311-312
2、Infrared mapping of surface-modified KEVLAR fiber-reinforced epoxy systems.Applied sectroscopy,1995,49(2)
3、Infrared spectral imaging of the interphse of epoxy-glass fiber-reinfrced composites under wet conditions. Applied Spectroscopy,1996,50(1):11-18
4、Structure characteriation of heat set and drawn polyamide66 fibers by FTIR spectroscopy. Mat Res Innovt,2001,4:155-160
拜托!若有 发到小女邮箱 linlan5751@163.com,小女子不胜感激!
您可能想找: 红外光谱(IR、傅立叶) 询底价
