原文由 hyheying 发表:原文由 lxj1206 发表:
The 95% confidence intervals were calculated by multiplying the standard deviations of the slopes by 2.776 as determined by the student t-test for 4 degrees of freedom.
95%的置信区间是通过乘以4-自由度的t-测试研究测得的斜率的标准偏差(2.776)计算而来的?
对这方面不甚了解,试着译一下。楼主应该把自己的翻译也贴出来啊
