主题:【分享】高分子测试方法 编号
medodo
Testing Items    Test Requirement
邵氏A型硬度    Shore Type A Hardness
    ASTM D2240-05
    ISO 7619-97
    GB/T 2411-1980(1989)
邵氏D型硬度    Shore Type D Hardness
    ASTM D2240-05
    ISO 7619-97
洛氏硬度    Rockwell Hardness
    ASTM D785-03
    ISO 2039-2:1987
    GB/T 9342-88
拉伸强度(模塑料,原料)    Tensile Strength (Mould Plastic& Materials)
    ASTM D638-03
    ISO 527-2:1993
    GB/T 1040-92
    ASTM D412-1998a(2002)e1 (橡胶)
    ISO 37-2005(橡胶)
    GB/T 528-1998(橡胶)
拉伸强度(膜材与片材)    Tensile Strength(Plastic Sheet & Film)
    ASTM D882-02 (单方向)
    ISO 527-3:1995 (单方向)
    GB/T 13022-1991 (单方向)
    ASTM D882-02 (MD/CD)
    ISO 527-3:1995 (MD/CD)
    GB/T 13022-1991 (MD/CD)
拉伸强度(编织袋)    Tensile Strength(Braided tapes )
    ISO 10371-1993(单方向)
    GB/T 8946-1998(单方向)
    GB/T 10454-2000(单方向)
    ISO 10371-1993(MD/CD)
    GB/T 8946-1998(MD/CD)
    GB/T 10454-2000(MD/CD)
断裂伸长率(模塑料、原料)    Elongation at break(Mould Plastic& Materials)
    ASTM D638-03
    ISO 527-2:1993
    GB/T 1040-92
    ISO 37-2005(橡胶)
    GB/T 528-1998(橡胶)
断裂伸长率(膜材与片材)    Elongation at break(Plastic Sheet & Film)
    ASTM D882-02 (单方向)
拉伸模量(模塑料、原料)    Tensile Modulus(Mould Plastic& Materials)
    ASTM D638-03
    ISO 527-2:1993
    GB/T 1040-92
拉伸模量(膜材与片材)    Elongation at break(Plastic Sheet & Film)
    ASTM D882-02 (单方向)
弯曲强度    Flexural Strength
    ASTM D790-03
    ISO 178:2001
    GB/T 9341-2000
弯曲模量    Flexural modulus
    ASTM D790-03
    ISO 178:2001
    GB/T 9341-2000
悬臂梁冲击强度    IZOD Impact Strength
    ASTM D256-05(有缺口)
    ASTM D4812-1999(无缺口)
    ISO 180:2000
    GB/T 1843-96
简支梁冲击强度    CHARPY Impact Strength
    ASTM D6110-04
    ISO 179-2:1997
    GB/T 1043-93
撕裂强度(膜材与片材)    Tearing strength(Plastic Sheet & Film)
    ASTM D1004-03  (单方向)
    ASTM D1938-02 (单方向)
    ISO 6383-1:1983 (单方向)
    GB/T 16578-96 (单方向)
    ASTM D1004-03  (MD/CD)
    ASTM D1938-02 (MD/CD)
    ISO 6383-1:1983 (MD/CD)
    GB/T 16578-96 (MD/CD)
    ASTM D624-00e1(橡胶)
    ISO 34-1:1994(橡胶)
    GB/T 529-1999(橡胶)
剥离强度    Peeling strength
    ASTM D5458-95(2001)(复合膜)
穿刺强度    Puncture Strength
    ASTM D4833-00e1
压缩强度    Compression Strength
    ASTM D695-02a
    ISO 604-02
    GB/T 1041-92
压缩模量    Compression Modulus
    ASTM D695-02a
    ISO 604-02
    GB/T 1041-92
压缩变形    Compression Set
    ASTM D395-03(弹性体)
    ASTM D395-03(橡胶)
    GB/T 7759-1996(橡胶)
    ISO 815(橡胶)
薄膜摆锤冲击强度    Tear Resistance of Film & Sheet by Pendulum Method
    ASTM D1922-03 (单方向)
    ASTM D1922-03 (MD/CD)
落锤冲击强度    Falling Weight Impact Strength
    ASTM D5628-96(2001)
    ASTM D4226-2000(PVC建材)
    ASTM D5420-04(Gardner Impact)
    GB/T 11548-89(板材)
    GB/T 14153-93(硬质塑料)
薄膜落镖冲击强度    Impact Resistance of Plastic Film by the Free-Falling Dart
    ASTM D1709-03
    GB/T 9639-1988
塑料及弹性体脆化温度    Brittleness Temperature of Plastics and Elastomers by Impact
    ASTM D746-04(需指定温度)
薄膜脆化温度    Brittleness Temperature of Plastic Sheeting by Impact
    ASTM D1790-02(薄膜)需指定温度点
    GB/T 11999-1989需指定温度点
    ASTM D1790-02(薄膜)未指定温度点
    GB/T 11999-1989 未指定温度点
薄膜与片材动静态磨擦系数    Static and kinetic Coefficient of Friction of Film and Sheet
    ASTM D1894-01
    ISO 8295-95
    GB 10006-88
模具收缩率    Mould Shrinkage
    ASTM D955-00
磨耗性能(Taber)    Taber Abrasion Resistance(需指定转数,磨轮,重量)
    ASTM D1044-99
    ASTM D4060-01
    ISO 9352:1995
密度    Density
    ASTM D792-00
    ISO 1183-1:2004
    GB/T 1033-86
    ASTM D1622-03 (硬质泡沫表观密度)
    ASTM D3574-03(软质泡沫表观密度)
    GB/T 6343-95 (泡沫表观密度)
尺寸    Size
    ASTM D5947-03
    ISO 4648-91
    GB/T 5723-93
面积重    Mass per Unit Area
    ASTM D5261-92(2003)
热学测试~
Melt Index    ASTM D1238-04 Melt-Mass Flow Rate (MFR) 质量流动速率
    ISO 1133:1997 Melt-Mass Flow Rate (MFR) 质量流动速率
    GB/T 3682-2000 Melt-Mass Flow Rate (MFR) 质量流动速率
    ASTM D1238-04 Melt Volume-Flow Rate (MVR) 体积流动速率
    ISO 1133:1997 Melt Volume-Flow Rate (MVR) 体积流动速率
    GB/T 3682-2000 Melt Volume-Flow Rate (MVR) 体积流动速率
HDT    ASTM D648-04 Deflection Temperature of Plastics 热变形温度
    ISO 75-2:2004 Deflection Temperature of Plastics 热变形温度
    GB/T 1634.1-2004 Deflection Temperature of Plastics 热变形温度
VST    ASTM D1525-00 Vicat Softening Temperature of Plastics 维卡软化点
    ISO 306:2004 Vicat Softening Temperature of Plastics 维卡软化点
    GB/T 1633-2000 Vicat Softening Temperature of Plastics 维卡软化点
TGA    ASTM D3850-94(2000) Solid Electrical Insulating Materials 热失重温度 TG
    ASTM D6370-99(2003) Rubber-Compositional Analysis 热失重温度 TG
DSC    GB/T19466.2-2004 玻璃化转变温度 Tg
    ISO11357:1999 玻璃化转变温度 Tg
    GB/T19466.3-2004 熔点 Tm
    ISO11357:1999 熔点 Tm
    GB/T19466.3-2004 Crystallization Temperature 结晶温度
    ISO11357:1999 Crystallization Temperature 结晶温度
    "DSC法 Heat of Crystallization 结晶热
    DSC法 Heat of Fusion 熔融热
CTE    ASTM D696-03 热膨胀系数 coefficient of thermal expansion
    ASTM D3386-2000 热膨胀系数 coefficient of thermal expansion
    ASTM DE831-03 热膨胀系数 coefficient of thermal expansion
CTC    ISO 8301-91 热抟导系数 Thermal Conduction Coefficient
    ASTM C518-02e1 热抟导系数 Thermal Conduction Coefficient
    ASTM C177-97 热抟导系数 Thermal Conduction Coefficient
PVC热稳定    GB 2917-88 PVC类聚合物热稳定性试验 Thermal Stable property of PVC
    ISO 305-90 PVC类聚合物热稳定性试验 Thermal Stable property of PVC
    ISO 182/1-4-90 PVC类聚合物热稳定性试验 Thermal Stable property of PVC
PEPP热稳定    ISO 4577-83 PE,PP热稳定性试验 Thermal Stable property of PE,PP
不饱和聚酯    GB 7193.5-87 Thermal Stable property of Unsaturated Polyester
    GB 7193.5-87 不饱和聚酯热稳定性试验
该帖子作者被版主 人来人往3积分, 2经验,加分理由:分享奖励!
KK-yiqi
楼主辛苦了,也很细心,三种标准的编号都列出来了。如果有相关的大家再补充,方便查询,呵呵。
