主题:【求助】【英雄帖】重金求红外好书,每本50~100积分赠与英雄(英雄已出现16次)
浏览0 回复60 电梯直达
zwyu
书目清单(排名不分先后,持续更新中)
Practical Sampling Techniques for Infrared Analysis
Applied Infrared Spectroscopy Fundamentals, Techniques, and Analytical Problem-Solving
The Design, sample handling, and applications of infrared microscopes
Modern Techniques in Applied Molecular Spectroscopy
Attenuated Total Reflectance Spectroscopy of Polymers Theory and Practice
Computerized quantitative infrared analysis
Applications of infrared, raman, and resonance raman spectroscopy in biochemistry
Internal reflection spectroscopy theory and applications
Infrared Methods for Gaseous Measurements
Infrared Spectroscopy of Biomolecules
In-situ spectroscopy of monomer and polymer synthesis
Modern Infrared Spectroscopy
RAPID METHODS FOR ANALYSIS OF EDIBLE OILS AND FATS BY FOURIER TRANSFORM INFRARED SPECTROSCOPY
An infrared spectroscopy atlas for the coatings industry
Principles and Practice of Spectroscopic Calibration
chromatography_Fourier transform infrared spectroscopy and its applications
Handbook of Infrared and Raman Spectra of Inorganic Compounds and Organic Salts (共4本)
Volume 1: Infrared and Raman Spectral Atlas of Inorganic Compounds and Organic Salts: Text and Explanations
Volume 2: Infrared and Raman Spectral Atlas of Inorganic Compounds and Organic Salts: Raman Spectra
Volume 3: Infrared and Raman Spectral Atlas of Inorganic Compounds and Organic Salts: Infrared Spectra
Volume 4: Infrared Spectra of Inorganic Compounds (3800-45cm-1)
兽药红外光谱集
所需书目如上,详见http://www.instrument.com.cn/ilog/BlogDetails.asp?username=zwyu&ILOG_ID=25571
pdf、djvu、超星等版本不限。要求电子版,可正常离线阅读。应助者每本50~100积分相赠,文本高清晰、能复制、带书签的,一律按最高的100分相赠。每本先到者得;后到成色更好者,亦得。
可直接跟帖,或站内短信,或发邮件至38833756@qq.com,或加QQ38833756联系。
书目和奖金兑现情况持续更新中(更新到2011.11.04,英雄出现16次,已兑现奖金1200,还有32本中英文书籍待助)。。。
英雄榜:
eginzon  应助8本  获得奖金670
hanguang627  应助3本(1本不全),获得奖金240
wxd54810770  应助1本,获得奖金100
tmeda应助1本,获得奖金100
sioc2000  应助2本(1本与eginzon撞车),获得奖金70
mouslaka  与eginzon撞车,安慰奖20
ghcily 虽未提供图书,但积极帮忙,鼓励奖10
已应助书籍清单:
Molecular spectroscopy of oxide catalyst surfaces
Infrared and raman spectroscopy of biological materials
木材波谱学
CRC Handbook of Fundamental Spectroscopic Correlation Charts
Secondary Structural Changes of Spray Dried Proteins with Fourier Transform Infrared Spectroscopy
干涉光谱仪
分子光谱学专论
Vibrational spectroscopy of biological and polymeric materials
The vibrational spectroscopy of polymers
紫外可见分光光度计及其应用
光谱仪器原理
傅里叶变换红外光谱分析_第二版
Fundamentals of Fourier Transform Infrared Spectroscopy
ghcily
http://www.ebookee.net/Fourier-Transform-Spectroscopy-Instrumentation-Engineering-dl/
试试看能不能下下来?
zwyu
谢谢专家关心。它那个是广告链接,没有资源的。
原文由 ghcily(ghcily) 发表:
试试看能不能下下来?
ghcily
原文由 zwyu(zwyu) 发表:
试试看能不能下下来?
可以下下来,但是需要付费。所以我没有下载,呵呵
zwyu
原文由 zwyu(zwyu) 发表:
试试看能不能下下来?
那个基本上是骗人的,让你先加会员,信用卡缴费。。。网上现在有太多的这种收费的链接,让你以为能下下来东西。我不看好这个,宁可去买纸质书。
ghcily
zwyu
所以啊,我才在这求。而且,小声说一句,那些书动辄几十到几百美金的
呵呵
纸质书市场上恐怕也不太好买吧
2010/6/3 12:09:53 Last edit by zwyu
ghcily
zwyu
书目有更新,增加了3本书。
2010/7/7 21:17:29 Last edit by zwyu
zwyu
终于有勋章啦!终于有勋章啦!!终于有勋章啦!!!
秀一下第一本书Fourier-Transform Spectroscopy Instrumentation Engineering的目录:
Table of Contents
Preface / xi
Chapter 1
Spectroscopy Instrumentation / 1
1.1 Introduction / 1
1.2 Types of Spectrometers / 1
1.2.1 Dispersive spectrometers
1.2.1 Dispersive spectrometers / 1
1.2.2 Filter-based spectrometers / 2
1.2.3 Fourier-transform spectrometers / 3
1.3 Advantages of FT Spectrometers / 4
1.3.1 Throughput or Jacquinot advantage / 4
1.3.2 Multiplex or Felgett advantage / 6
1.4 Discussions on FT Spectrometer Advantages / 8
References / 9
Chapter 2
Signal-to-Noise Ratio / 11
2.1 Signal-to-Noise Ratio Defined / 11
2.2 Quantifying Signal-to-Noise Ratio / 12
2.3 Practical Considerations / 15
Chapter 3
Principles of Interferometer Operation / 17
3.1 Overview / 17
3.2 Quantitative Explanation / 19
3.2.1 Light as a wave / 19
3.2.2 Measurable light quantity / 21
3.2.3 Interference and superposition / 22
3.2.4 Polychromatic source / 24
3.2.5 Fourier-transform routine / 25
3.3 Theoretical Resolution / 26
3.3.1 Retardation distance / 26
3.3.2 Divergence angle / 29
3.4 Interferogram Digital Processing / 32
3.4.1 Apodization / 32
3.4.2 Zero filling / 33
3.4.3 Phase correction / 34
References / 34
Chapter 4
Interferometer Alignment Errors / 35
4.1 Error Characteristics / 37
4.2 Interferogram-Modulation Error / 38
4.3 Interferogram-Sampling Error / 43
References / 44
Chapter 5
Motion Components and Systems / 45
5.1 Actuators / 46
5.1.1 Actuator types / 46
5.1.2 Performance specifications for actuators / 46
5.2 Driver and Amplifier / 48
5.3 Bearings and Coupling Mechanism / 48
5.3.1 Bearing types / 49
5.3.2 Performance specifications for bearings / 49
5.3.3 Discussion on bearings / 51
5.4 Position Sensor / 53
5.4.1 Laser interferometer / 53
5.4.2 Sensor specifications / 56
5.5 Homodyne Interferometer Sources of Error / 56
5.5.1 Source wavelength variations / 57
5.5.2 Refractive index variations / 57
5.5.3 Laser detector errors / 57
5.5.4 Polarization errors / 58
5.5.5 Alignment errors / 58
5.6 Actuator, Sensor, and Mirror Mounting / 59
5.6.1 Actuator location vs. center of mass / 59
5.6.2 Sensor location vs. mirror location / 59
5.6.3 Sensor location vs. actuator location / 59
5.7 Digital Motion Controller / 60
References / 61
Chapter 6
Interferogram Data Sampling / 63
6.1 Step Scan vs. Continuous Scan / 63
6.2 Sampling Period / 65
6.2.1 The absolute minimum: the Nyquist criteria / 65
6.2.2 More than the Nyquist minimum / 67
6.2.3 Anti-alias filter / 68
6.3 Accuracy with Respect to OPD / 69
6.3.1 Effects of sampling errors to the output spectrum / 70
6.3.2 Sources of error / 72
6.4 Repeatable Clock Position / 73
6.5 Hardware Methods / 73
References / 74
Chapter 7
Data Acquisition / 75
7.1 DAQ Hardware Formats / 75
7.2 Analog Inputs / 75
7.2.1 Number of channels / 75
7.2.2 Sampling rate / 76
7.2.3 Resolution / 76
7.2.4 Input ranges / 76
7.2.5 Accuracy / 77
7.3 Hardware Triggering and Clock Signal / 77
7.4 Effects of ADC Resolution on Spectral SNR / 78
Chapter 8
The Detector / 81
8.1 Noise-Equivalent-Power / 81
8.2 Spectral SNR quantification / 82
8.3 Detector Types / 85
8.4 Selection Guidelines / 85
8.4.1 Spectral range and responsivity / 86
8.4.2 Active area / 86
8.4.3 Noise and detectivity /86
8.4.4 Linearity / 87
8.4.5 Temporal bandwidth / 88
8.4.6 Summary / 88
References / 87
Chapter 9
Consideration of Optics and Interferometer Alignment / 91
9.1 System Throughput / 91
9.2 Lenses vs. Mirrors / 93
9.3 Interferometer Alignment Procedure / 94
Chapter 10
Signal-to-Noise Ratio Enhancement Techniques / 97
10.1 Identification of Error Sources / 97
10.1.1 Detector noise / 97
10.1.2 Digitization noise / 98
10.1.3 Interferometer alignment error / 98
10.1.4 Sampling error / 99
10.1.5 Light-source variation / 99
10.2 Averaging / 100
10.3 Temporal Modulation and Bandwidth Narrowing / 101
10.4 Spectral-Bandwidth Narrowing / 102
10.5 Spectral Post-Processing / 103
10.6 Double Beaming / 105
10.6.1 Electrical subtraction / 105
10.6.2 Optical subtraction / 106
10.7 Gain ranging / 107
10.8 Dynamic Tilt Compensation / 107
References / 108
Appendix A
Simulation of Static-Tilt Error / 109
Appendix B
Sampling Circuit Example / 111
Appendix C
Simulation of Sampling Error / 113
Index / 115
Preface
This book covers the engineering aspects of Michelson-interferometer-based Fourier-transform (FT) spectrometers. While other Fourier-transform spectroscopy textbooks have generally focused on the theoretical aspects and applications, this book provides insights to the design and instrumentation of FT spectrometers. This book is intended for scientists and engineers who wish to understand the operation of the instrument to the extent where they have the knowledge to improve results through hardware, software and/or procedural modifications. This book is also a proper introductory text for an engineer who plans to design a custom FT spectrometer. Many applications today require the FT spectrometer to perform close to its limitations, such as taking many quantitative measurements in the visible and in the near-infrared wavelength regions. In such cases, the instrument should not be considered as a perfect "black box." Knowing where the limitations of performance arise and which components must be improved are crucial to obtaining repeatable and accurate results. One of the objectives of this book is to help the user identify the instrument's bottleneck. The book begins with an overview of the types of spectrometers and the fundamental advantages of FT spectrometers (Chapter 1). Chapter 2 is devoted to clearly defining signal-to-noise ratio (SNR), a performance figure extensively used throughout this book. In Chapter 3, details of the interferometer operation are discussed. The design and limitations of the subsystems and components that include the motion components, the analog-to-digital (A/D) conversion process, the detection system, and the optical components are covered in Chapters 4 through 9. Chapter 10 introduces various practical techniques to identify the limiting source of error, and techniques to improve the obtainable SNR. I am indebted to Professor Kamal Youcef-Toumi at Massachusetts Institute of Technology (MIT) for giving me the opportunities to be involved in various first-rate R&D projects during my time at MIT, one of which led me to the exciting world of FT spectroscopy. I deeply thank Merry Schnell of SPIE, the main editor of this project, for her thoroughness and professionalism. Bradley M. Stone and David Ball did an excellent job in reviewing the original manuscript. Rick Hermann and Timothy Lamkins of SPIE provided generous assistance from the early stage of the project. All have my deepest appreciation. Vidi Saptari September 2003
xi
fzhang666
