主题:请问金属钯如何配成基改剂?
浏览0 回复8 电梯直达
epcomer
在做石墨炉时,手头上只有金属的钯,试过用硝酸消解,但好像还是不能溶解,请问该如何才能配成溶液,
pony2002
Standard material :  Metal palladium 99.9% up
1.000g of metal palladium is heated and dissolved with 30ml
of aqua regia and is vaporized to dryness on a water bath.
Hydrochloric acid is added and it is vaporized to dryness
again. Hydrochloric acid and water are added to dissolve it.
It is then diluted with water to 1000ml accurately.
Hydrochloric acid concentration is set at 0.1N.
这个是Pd标准溶液的配制,参考一下吧
epcomer
好的,但这是理论上的,但不知实际中有没有简单一点的方法
dhlsh
jessie2005
epcomer
linhall
pony2002
标准物质: 金属钯 99.9% 以上
1.000g 的金属钯加热溶解于30ml 的王水中,在水浴上蒸
发至干。加入盐酸,再次蒸发至干。加入盐酸和水溶
解。然后用水准确地稀释到 1000ml。盐酸浓度调节到 0.1N。
yzyxq
