bar MPa psi atm 之间的换算关系
大气压单位之间的换算
A.1兆帕(MPa)
=145磅/英寸2(psi)
=10.2千克/厘米2(kg/cm2)
=10巴(bar)
=9.8大气压(atm)
B.1磅/英寸2(psi)
=0.006895兆帕(MPa)
=0.0703千克/厘米2(kg/cm2)
= 0.0689巴(bar)
=0.068大气压(atm)
C.1巴(bar)
=0.1兆帕(MPa)
=14.503磅/英寸2(psi)
=1.0197千克/厘米2(kg/cm2)
=0.987大气压(atm)
D.1大气压(atm)
=0.101325兆帕(MPa)
=14.696磅/英寸2(psi)
=1.0333千克/厘米2(kg/cm2)
=1.0133巴(bar)
1atm=101325Pa=1.01×105
