主题:透射电子显微学中常用的缩写词
浏览0 回复6 电梯直达
ustb
ACF    absorption correction factor
A/D    analog to digital (converter)
ADF    annular dark field
AEM    analytical electron microscope/microscopy
AES    Auger electron spectrometer/spectroscopy
AFF    aberration-free focus
ALCHEMI    atom location by channeling-enhanced microanalysis
APB    anti-phase domain boundary
ATW    atmospheric thin window
BF    bright field
BFP    back focal plane
BSE    backscattered electron
BSED    backscattered-electron diffraction
BZB    Brillouin-zone boundary
C(1,2,etc..)condenser (l, 2, etc.) lens
CB    coherent bremsstrahlung
CBED    convergent-beam electron diffraction
CBIM    convergent-beam imaging
CCD    charge-coupled device
CCF    cross-correlation function
CCM    charge-collection microscopy
CDF    centered dark field
CF    coherent Fennel/Foucault
CFEG    cold field-emission gun
CL    Cathodeoluminescence
CRT    cathode-ray tube
CS    crystallographic shear
CSL    coincident-site lattice
DF    dark field
DOS    density of states
DP    diffraction pattern
DQE    detection of quantum efficiency
DSTEM    dedicated scanning transmission electron microscopy
DTSA    desktop spectrum analyzer
EBIC    electron beam-induced current/conductivity
EELS    electron energy-loss spectrometry
EFI    energy-filtered imaging
ELNES    energy-loss near-edge structure
ELP    energy-loss program (Gatan)
EMMA    electron microscope microanalyzer
EMS     electron microscopy image simulation
EPMA    electron probe microanalyzer
ESCA    electron spectroscopy for chemical analysis
ESI    electron spectroscopic imaging
EXAFS    extended X-ray absorption fine structure
EXELFS    extended energy-loss fine structure
FCF    fluorescence correction factor
FEG    field-emission gun
FET    field-effect transistor
FFT    fast Fourier transform
FOLZ    first-order Laue zone
FSE    fast secondary electron
FTP    file transfer protocol
FWHM    full width at half maximum
FWTM    full width at tenth maximum
GB    grain boundary
GCS    generalized cross section
GIF    Gatan image filter
GOS    generalüed oscillator strength
HAADF    high-angle annular dark field
HOLZ    higher-order Laue zone
HPGe    high-purity germanium
HRTEM    high-resolution transmission electron microscope/microscopy
HV    high vacuum
HVEM    high voltage electron microscope/microscopy
IDB    inversion domain boundary
IEEE    International Electronics and Electrical Engineering
IG    intrinsic Ge
IVEM    intermediate voltage electron microscope/microscopy
K-M    Kossel-Möllenstedt
LEED    low-energy electron diffraction
LLS    linear least-squares
LUT    look-up table
MC    minimum contrast
MCA    multichannel analyzer
MDM    minimum detectable mass
MLS    multiple least-squares
MMF    minimum mass fraction
MSDS    material safety data sheets
NCEMSS    National Center for Electron Microscopy simulation system
NIH    National Institutes of Health
NIST    National Institute of Standards and Technology
OR    orientation relationship
OTEDP    oblique-textured electron diffraction pattern
PB    phase boundary
P/B    peak-to-background ratio
PEELS    parallel electron energy-loss spectrometer/spectroscopy
PIMS    Precision Ion-Milling System
PIPS    Precision Ion-Polishing System
PM    photomultiplier
POA    phase-object approximation
QHRTEM    quantitative high-resolution transmission electron microsc.
RB    translation boundary (yes, it does!)
RCP    rocking-beam channeling patterns
RDF    radial distribution function
REM    reflection electron microscope/microscopy
RHEED    reflection high-energy electron diffraction
RHF    relativistic Hartree-Fock
RHFS    relativistic Hartree-Fock-Slater
SAD    selected-area diffraction
SE    secondary electron
SEELS    serial electron energy-loss spectrometer/spectrometry
SEM    scanning electron microscope/microscopy
SF    stacking fault
SHRLI    simulated high-resolution lattice images
SIMS    secondary ion mass spectrometry
S/N    signal-to-noise ratio
SOLZ    second-order Laue zone
SRM    standard reference material
STEM    scanning transmission electron microscope/microscopy
STM    scanning tunneling microscope/microscopy
TB    twin boundary
TEM    transmission electron microscope/microscopy
TMBA    too many bloody acronyms
UHV    ultrahigh vacuum
UTW    ultra thin window
V/F    voltage to frequency (converter)
VLM    visible-light microscope/microscopy
WB    weak beam
WBDF    weak-beam dark field
WDS    wavelength-dispersive
WP    whole pattern
WPOA    weak-phase object approximation
WWW    World Wide Web
XANES    X-ray absorption near-edge structure
XEDS    X-ray energy-dispersive
XRD    X-ray diffraction
YBCO    yttrium-barium-copper oxide
YAG    yttrium-aluminum garnet
ZAF    atomic number, absorption, fluorescence correction
ZAP    zone-axis pattern
ZOLZ    zero-order Laue zone
shxie
赞!看到一个词QHRTEM是怎么回事?这个定量是通过什么得到的呢?从来没见过。
ustb
原文由 shxie 发表:
你还记得9月份在物理所贾春林老师的那个报告吗,他的报告里就有这部分的内容,好像是做图像强度定量比较的,记不太清了
TEM_ABC
定量高分辨,顾名思义,就是不但要知道原子在哪里,还要知道有多少原子在那里。这就不是只玩玩儿仪器就能解决,而需要些理论基础了。如果有兴趣,不妨从高分辨像的模拟计算入手。
feverfew
house2000
llover
