reachability,可达性;能达性
reachable set,可达集;能达集
reachable state,可达状态;能达状态
reaction gas,反应气
reaction gas chromatography,反应
气相色谱法
reaction interval,反应区间;反应程
reaction wheel,反作用轮
reaction wheel control,反作用轮控制
reactive energy meter[varhour meter],无功电度表[乏时计]
reactive powermeter,无功功率表
read,读
read-only memory(ROM),只读存储器
read-only storage,只读存储器
readability,易读性;可读度;读数精度
reading bridge,读数电桥
reading strain,应变读数
readjustments,重调
readout time,读出时间
real gas critical flow coefficient,真实气体临界流量系数
real-aperture side-looking airborne radar,实孔径侧视雷达
real image,实象
real strain,真实应变
real time,实时
real time analysis,实时分析
real time analyzer,实时分析仪
real-time clock,实时时钟
real time control,实时控制
real-time control system,实时控制系统
real time date processing,实时数据处理
real time expert system,实时专家系统
real time input,实时输入
real time output,实时输出
real time remote control,实时遥控
real time simulation,实时仿真
real time simulation algorithm,实时仿真算法
real time system,实时系统
real time telemetry,实时遥测
real-time trend panel,实时趋势画面
realizability,可实现性;能实现性
realization of international temperature scale,国际温标的复现
rearrangedmolecular ion,重排分子离子
rearrangement ion,重排离子
receiver element,接收器元件
recessed bearing,槽形支承
reciprocal linear dispersion,倒数线色散
reciprocating piston flowmeter,簇复活塞式流量计
reciprocating pump,往复泵
reciprocity calibration,互易法校准
recombination type transducer [sensor],复合型传感器
record,记录
recorder,记录仪
recording,记录
recording anemometer,风速计
recording chart,记录纸
recording clock,自记钟
recording device,记录装置
recording instrument,自记仪器
recording(measuring)instrument,记录(测量)仪器
recording medium,记录介质
recording snow-gauge,自记雪量计
recording sync,记录同步
recording theodolite,自记经纬仪
recovery time,恢复时间
rectangular coordinate type potentiometer,直角坐标式电位差计
rectifier,整流器;纠正仪
rectifier instrument,整流式仪表
rectilinear ordinates recording instrument,直线坐标记录仪
rectilinear vibration,直线振动
recursive estimation,递推估计
recycle chromatography,循环色谱法
redox electrode assembly,氧化还原复合电极
redox potential meter,氧化-还原电位测定仪
reduced capacity trim,低容量阀内件
reduced model,降阶模型
reduced order observer,降阶观测器
reduced viscosity,还原粘度
reducing plane table equipment,归算平板仪
reduction of area,断面收缩率
reduction of length,缩短率
redundancy computer system,冗余计算机系统
redundancy unit,冗余单元;冗余设备
redundant information,冗余信息
reentry control,再入控制
reference block [specimen],比较试块;对比试块;参考试块
reference chart,参比记录纸
reference coil,参考线圈;基准线圈
reference column,参比柱
reference condition,参比条件
reference electrode,参比电极
reference holder,参比物支持器;参比器
reference junction,参比端
reference junciton error(of thermocouple),(热电偶的)参比端误差
(reference junction temperture) compensator,(参比端温度)补偿器
reference line,参比线
reference load calibrating machine,基准测力机
reference material,参比物质
reference model,参考模型
reference operating condition,参比工作条件
reference performance characteristice,参比性能特性
reference pressure,参比压力
reference range,参比范围
reference sample,参比试样
reference signal,参比信号
reference sound intensity,参考声强
reference sound power,参考声功率
rdference sound pressure,参考声压
reference source,参比源
reference standard,参比[考]标准(器)
reference table (of thermocouple),(热电偶的)分度表
reference test pieces,对比试块
reference value,参比值
reference-value method,参比值法
reference-value scale(of a quantity or property),(量或特性)参比值标度
reference variable,参比变量
reference voltage,基准电压
reference wave,参考声束
reflected wave,反射波;回波
reflecting sketchmaster,反光转绘仪
reflection electron microscope,反射电子显微镜
reflection grating,反射光栅
reflection method,脉冲反射法
reflection nephoscope,反射测云器
reflective optic tachometric transducer,反光式转速传感器
reflectometer,反射表
reflector path,外光路
refracting telescope,折射望远镜
refractive humidity transducer [sensor],折射式湿度传感器
refractometer,折射盐度计
refrigerant(pressure)gauge,致冷压力表
refrigeration,致冷
regenerative braking,回馈制动;再生制动
regional model,区域模型
register,寄存器
register(of an integrating instrument),(积分式仪表的)计度器
registered standard,注册标准
regression,回归
regular velocity distribution,规则速度分布
regulating device,调节装置
regulating unit,调节单元
regulation,法规;调节
regulator,调节器
rejection,抑制
relative aperture,相对孔径
relative error,相对误差
relative flow coefficient,相对流量系数
relative gravity surver,相对重力测量
relative humidity,相对湿度
relative (measurement) method,相对式测量法
relative precision,相对响应值
relative retention value,相对保留值
relative sensitivity coefficient,相对灵敏度系数
relative stability,相对稳定性
relative tolerance between forward and backward in indicating value,示值进回程相对误差
relative travel,相对行程
relative variation in the indicating value,示值相对变动值
relative viscosity,相对粘度
relaxation process,弛豫过程
relaxation testing machine,松弛试验机
relaxation vibration,张弛振动
relay,继动器;继电器
relay characteristics,继电(器)特性
relay control system,继电控制系统
release mechanism for plankto net,浮游生物网闭锁器
relevant failure,关联失效
relevant specification,有关规范
reliability,可靠性;可靠度
reliability assessment,可靠性评估
reliability block diagram,可靠性方框图
reliability certification,可靠性认证
reliability compliance test,可靠性试验证试验
reliability design review,可靠性设计评审
reliability determination test,可靠性测定试验
reliability evaluation,可靠性评定
reliability evaluation from demonstration data,利用验证数据的可靠性评定
reliability growth,可靠性增长
reliability improvement,可靠性改进
reliability model,可靠性模型
reliability program,可靠性计划
relief valve,释放阀
reluctive pressure transducer,磁阻式压力传感器
reluctive transducer [sensor],磁阻式传感器
remanent attraction force,残留吸力
