原文由 八十后的牛(jianquan69) 发表:
可以进峰纯度看,可以用AMDIS看,看自动积分,也会显示峰的类型。
Amdis里有peak tailing, 可以参考。
(Peak Tailing: The ratio of the area to the right (later time) of the center of the peak to area to on the left of the peak (earlier time). A well-formed peak has a value near one. Excessive tailing will yield values much greater than 1.)
