主题:【讨论】HPLC用于含量分析,用除去残媒吗?
haitun0451
按照欧洲药典-2034“Residual solvents are limited according to the principles defined in chapter 5.4, using general method 2.4.24 or another suitable method. Where a quantitative determination of a residual solvent is carried out and a test for loss on drying is not carried out, the content of residual solvent is taken into account for calculation of the assay content of the substance, the specific optical rotation andthe specific absorbance.”是不是做含量分析时除了去掉水分值,还要去掉残媒值啊?
您可能想找: 液相色谱(LC) 询底价
阿怪
你做含量是用对照的吧?用的话就不能除掉水分和溶残啊。除非看归一化。
