主题:【讨论】How do you believe that UFO is true? If we study UFO, what kinds of instruments will be used?(sign up 28 Aug)
浏览0 回复11 电梯直达
symmacros
The relative news:
A huge illuminant unidentified flying object (UFO) was reported by multiple airliner pilots in the sky above Shanghai, the Oriental Morning Post reported Tuesday.
The pilot of airliner CZ6554 said on his micro blog that a huge spherical illuminant was seen in the sky, 10,700 meters above Shanghai at 9 pm on August 20. “The luminant was really round and getting huger, (looks) hundreds times bigger than the moon and the diameter of the luminant was longer than 50 sea miles,” the pilot said on his micro blog.
The pilot said the aircrew of more than ten other airliners flying above Shanghai also reported the illuminant object, one by one.
At almost the same time, a halo in the sky above Beijing was seen by local people.
A netizen named Chen Xu published a photo of the halo on his micro blog.
Chen said the halo was small at first, then expanded, moved north, and disappeared several minutes later.
The UFO reports follow another report from Southwest China's Chongqing municipality three days before August 20. A UFO was seen above the landing route of the city's airport, forcing two planes to land in Guiyang of Guizhou province and Xi'an of Shaanxi province, respectively.
该帖子作者被版主 天晴了10积分, 2经验,加分理由:sign post
arvid2007
I do not believe it ,because there is always proved not ture.
该帖子作者被版主 smileqing1积分, 2经验,加分理由:s
abcdefghijkl123
I do not believe it 。
mengzhaocheng
I do not believe it
yuduoling
i don't believe it
该帖子作者被版主 smileqing1积分, 2经验,加分理由:sign
天晴了
I don't believe UFO because most of the witnesses can not offer solid proof of UFO.
该帖子作者被版主 zouhua12101积分, 2经验,加分理由:sign
dahua1981
qlmkk
I do not believe it,too.
watertime
I don't believe that, because there is no evidence.
symmacros
There are some reports on UFO, E.T(Extra-Terrestrial) recently,especially,a Italy women was captured by E.T and then born a E.T baby. But I also do not believe them as them are no proved anymore.
hxf119
i donot know
