低群延迟色散反射镜,Low GDD Ultrafast mirror是欧洲进口的
低群延迟色散超快反射镜和
低GDD反射镜,它专业为飞秒激光应用而设计,通过精心选择镀膜膜系,提供高反射率和
低GDD性能,非常适合Ti:S激光,钕玻璃激光,而玻璃激光,掺Yb激光使用。
低GDD反射镜专业为飞秒激光应用而设计,在特定入射角和特定波长给予优化设计,从获得low GDD 值 (from -10 fs2 to 10 fs2 at design bandwidth)
除此之外,这种GDD反射镜镀膜适合外部的要求宽带的激光操作应用。
低群延迟色散反射镜(Low GDD Ultrafast mirror)规格参数
Material | UVFS |
Diameter tolerance | +0/-0.1 mm |
Thickness tolerance | ±0.1 mm |
Clear Aperture | >90% |
Surface quality | 20-10 S-D |
Surface flatness | <λ/8 @ 632.8 nm |
Reflection GDD for s polarization | -10 fs² to 10 fs² |
Reflection GDD for p polarization | -20 fs² to 20 fs² |
Protective chamfers | <0.25 mm x 45° |
标准低群延迟色散反射镜订购参数
AOI, deg | Reflectivity (average), % | Dimensions, mm | Wavelength, nm | Product ID |
0 | >99.5 | Ø12.7 x 5 | 380-420 | 1-OS-2-0127-5- |
0 | >99.0 | Ø25.4 x 5 | 250-270 | 1-OS-2-0254-5- |
0 | >99.5 | Ø25.4 x 5 | 760-840 | 1-OS-2-0254-5- |
45 | >99.5 | Ø12.7 x 5 | 340-370 | 1-OS-2-0127-5- |
45 | >99.5 | Ø25.4 x 5 | 380-420 | 1-OS-2-0254-5- |
45 | >99.5 | Ø25.4 x 5 | 500-532 | 1-OS-2-0254-5- |
0 | >99.5 | Ø12.7 x 5 | 760-840 | 1-OS-2-0127-5- |
45 | >99.0 | Ø12.7 x 5 | 250-270 | 1-OS-2-0127-5- |
0 | >99.0 | Ø12.7 x 5 | 250-270 | 1-OS-2-0127-5- |
0 | >99.5 | Ø25.4 x 5 | 1000-1060 | 1-OS-2-0254-5- |
0 | >99.5 | Ø25.4 x 5 | 380-420 | 1-OS-2-0254-5- |
0 | >99.5 | Ø25.4 x 5 | 340-370 | 1-OS-2-0254-5- |
0 | >99.5 | Ø25.4 x 5 | 500-532 | 1-OS-2-0254-5- |
45 | >99.5 | Ø25.4 x 5 | 340-370 | 1-OS-2-0254-5- |
45 | >99.5 | Ø12.7 x 5 | 760-840 | 1-OS-2-0127-5- |
45 | >99.5 | Ø12.7 x 5 | 500-532 | 1-OS-2-0127-5- |
45 | >99.0 | Ø25.4 x 5 | 250-270 | 1-OS-2-0254-5- |
45 | >99.5 | Ø25.4 x 5 | 760-840 | 1-OS-2-0254-5- |
45 | >99.5 | Ø12.7 x 5 | 1000-1060 | 1-OS-2-0127-5- |
0 | >99.5 | Ø50.8 x 6 | 380-420 | 1-OS-2-0508-6- |
相关商品
http://www.felles.cn/fanshejing/gdd.html
