主题:【讨论】原料药含量 上限101.0% or 102.0%?
浏览0 回复3 电梯直达
liuba911
原料药在没有规定上限的时候,上限应该是101.0%还是102.0%?CP上是101.0%,不知道EP/USP上是怎么规定的?请高人指点一下
symmacros
可能是不同的检测方法的误差范围不同,表示的上限不同,每种药可能不一样。
myreebok
poorlittle
I suggest that it should be free to use Chinese, English or the combination of Chinese and English in submitting or responding a post.  However, the post is preferable to be related to technical English rather than purely technical matter.
