第十九章 经典
液相色谱法
薄层色谱法:TLC
吸附:adsorption
活化:activation
脱活性:deactivation
交联度:degree of cross linking
交换容量:exchange capacity
薄层板:thin layer plate
展开剂:developing solvent ,developer
临界胶束浓度:criticak micolle concentration ,CMC
相对比移值:relative Rf, Rr
分离度:resolution ,R
分离数:separation number,SN
煅石膏:Gypsum
羧甲基纤维素钠:CMC-Na
吸收光谱联用:TLC-UV
薄层色谱-荧光联用:TLC-F
薄层色谱-红外吸收光谱联用:TLC-IR
薄层色谱法:TLC-MS
纸色谱法:paper chromatography
上行展开:ascending development
下行法展开:descending development
双向展开:two dimensional develoooment
第二十章
气相色谱法
气相色谱法:gas chromatography
前延峰:leading peak
拖尾峰:tailing peak
对称因子:symmetry factor,fs
保留时间:retention time
保留体积:retention volume
死时间:dead time
调整保留时间:asjusted retention time
半峰宽:peak width at half height,W1/2 or Y1/2
峰宽:peak width,W
等温线:isotherm
理论塔板高度:height equivalent to atheoretical plate
化学键合相:chemically bonded phase
丁二酸二乙二醇聚酯:polydiethylene glycol succinate,PDEGS,DEGS
高分子多孔微球:GDX
苯乙烯:STY
乙基乙烯苯:EST
二乙烯苯:DVB
涂壁毛细管柱:wall coated open tubular column,WCOT
载体涂层毛细管柱:supprot coated open tubular column,SCOT
热导检测器:thermal conductivity detector,TCD
氢焰离子化检测器:hydrogen flame ionization detector,FID
电子捕获检测器:electron capture detector ,ECD
噪声:noise,N
漂移:drift,d
灵敏度:sensitivity
检测限(敏感度):detectability,D,M
分离度:resolution
归一化法:normalization method
外标法:external standardization
第二十一章 高效
液相色谱法
高效
液相色谱法:high performance liquid chromatography,HPLC
高速
液相色谱法:high speed LC,HSLC
高压
液相色谱法:high pressure LC,HPLC
高分辨
液相色谱法:high resolution LC,HRLC
液固吸附色谱法(液固色谱法):liquid-solid adsorption chromatography,LSC
液液色谱法:liquid-liquid chromatography,LLC
正相:normal phase,NP
反相:reversed phase,RP
化学键合相色谱法:bonded phase chromatography,BPC
十八烷基:octadecylselyl,ODS
离子对色谱法:paired ion chromatography,PIC
反相离子对色谱法:RPIC
离子抑制色谱法:ion suppression chromatography,ISC
离子色谱法:ion chromatography,IC
手性色谱法:chiral chromatography,CC
环糊精色谱法:cyclodextrin chromatography,CDC
胶束色谱法:micellar chromatography,MC
亲和色谱法:affinity chromatography,AC
固定相:stationary phase
化学键合相:chemically bonde phase
封尾、封顶、遮盖:end capping
手性固定相:chiral stationary phase,CSP
恒组成溶剂洗脱:isocraic elution
梯度洗脱:gradient elution
紫外检测器:ultraviolet detector,UVD
荧光检测器:fluorophotomeric detector,FD
电化学检测器:ECD
示差折光检测器:RID
光电二极管检测器:photodiode array detector ,DAD
三维光谱-波谱图:3D-spectrochromatogram
蒸发光散射检测器:evaporative light scattering detector,ELSD
安培检测器:ampere detector,AD
高效毛细管电泳法:high performance capillary electrophoresis,HPCE
淌度:mobility
电泳:electrophoresis
电渗:electroosmosis
动力进样:hydrodynamic injection
电动进样:electrokinetic injection
毛细管区带电泳法:capillary zone electrophoresis,CZE
胶束电动毛细管色谱:micellar electrokinetic capillary chromatography,MECC
毛细管凝胶电泳:capillary gel electrophoresis,CGE
筛分:sieving
绪论
释药系统(drug delivery system,DDS)
中国药典(Chinese Pharmacopoeia,ChP)
美国药典(The United States Pharmacopoeia,USP)
美国国家处方集(The National Formulary,NF)
英国药典(British Pharmacopoeia,BP)
欧洲药典(European Pharmacopoeia,Ph.Eup)
国际药典(The International Pharmacopoeia,Ph.Int)
良好药品实验研究规范(Good Laboratory Practice,GLP)
良好药品生产规范(Good Manufacture Practice,GMP)
良好药品供应规范(Good Supply Practice,GSP)
良好药品临床试验规范(Good Clinical Practice,GCP)
分析质量管理(Analytical Quality Control,AQC)
