主题:[转帖]实验很重要,生命也很重要--实验室常见致癌物质和诱发畸变物质
浏览0 回复2 电梯直达
瓢虫
该帖子已被穿越时空设置为精华; 奖励积分记录: 穿越时空(2分)
生命很重要,鉴于很多新虫没有金币,或者网速限制,你可以留下你的email索取~
大家珍爱生命~
实验室致癌物质和诱发畸变物质
CARCINOGENS 致癌物质
Carcinogens and substances capable of inducing cancer. These
substances must be subject to strict guidelines such as those
published by the International Agency for Research on Cancer
when they are stored, used, and disposed of. Avoid exposure
where exposure is unavoidable, keep it as low as reasonably
achievable. The list of known carcinogens is continually updated.
(See next page for some examples of carcinogens).
致癌类物质要避免直接暴露在空气中,其名单以国际癌症研
究中心公布的数据为准。
Mutagens are substances causing permanent transmissible
alterations in genetic information. Teratogens are agents
interfering with normal prenatal development causing
abnormalities in the fetus. Exposure to mutagens and
teratogens should be kept as low as possible.
诱发突变性物质,是指那些引起在基因中的可遗传的
变化的物质。诱发畸变性物质,是指可以引起胎儿在
出生前产生不正常变化的物质。
实验室致癌物质和诱发畸变物质
您可能想找: 激光拉曼光谱(RAMAN) 询底价
天一
sfwq
其它的化学物质没接触过,只接触过三氯甲烷和二氯甲烷,因为是要吹干,可以说是直接向大气排放,吸了多少进去就不知道了,不知道有没有可以预防方法.我知道三氯甲烷和二氯甲烷不稳定,见光分解,阳光明媚的时候才用这个
