原文由 Alann(lannfeng) 发表:
在2011/65/EU 关于电子电器设备(EEE)的定义中写道:
(1) ‘electrical and electronic equipment’ or ‘EEE’ means equipment which is dependent on electric currents or electromagnetic fields in order to work properly and equipment for the generation, transfer and measurement of such currents and fields and designed for use with a voltage rating not exceeding 1 000 volts for alternating current and 1 500 volts for direct current;
(2) for the purposes of point 1, ‘dependent ‘ means, with regard to EEE, needing electric currents or electromagnetic fields to fulfil at least one intended function;
那么一款带灯的床,算不算依赖电流实现了一项预定的功能(照明)而变成EEE呢?这样的例子还与很多。
应该不算,我记得之前有过泰迪熊的解释。
定义产品的时候,主要还是看主要功能。可以参考RoHS/WEEE FAQ的内容。
