【作者】 曾令高; 李静;
【Author】 Zeng Linggao1,Li Jing2(1.Chongqing Institute for Drug Control,Chongqing,China 401121; 2.Chongqing Yaoyou Pharmaceutical Co.,Ltd.,Chongqing,China 401121)
【机构】 重庆市药品检验所; 重庆药友制药有限责任公司 重庆401121; 重庆401121;
【摘要】 目的用高效
液相色谱法(HPLC法)测定鱼腥草素钠含量。方法采用Diamonsil C18色谱柱(250mm×4.6mm,5μm),以甲醇-水-10%四丁基氢氧化铵(70∶30∶0.3)为流动相,检测波长为283nm。结果鱼腥草素钠质量浓度线性范围为7.408~37.04μg/mL(r=0.9998),平均回收率为98.72%,RSD为1.6%。结论HPLC法简便、准确,可用于鱼腥草素钠片的质量控制。 更多还原
【Abstract】 Objective To establish a HPLC method for determination of sodium houttuyfonate tablets.Methods Using a Diamonsil C18 column(250 mm×4.6 mm,5 μm).The mobile phase consisted of methane alcohol-water-tetrabutylammonium hydroxide solution(10%)(70 ∶30 ∶0.3).The detection was carried out with a dinode array detector at 283 nm.Results The calibration curves were linear between 7.408 and 37.04 μg/mL(r=0.999 8).The average recovery rate was 98.72%,RSD=1.6%.Conclusion This method is convenient and accurate... 更多还原
【关键词】 高效
液相色谱法; 鱼腥草素钠片; 含量;
【Key words】 HPLC; sodium houttuyfonate tablets; assay;
