【作者】 马琳; 李勇军; 何迅; 兰燕宇; 王爱民; 王永林;
【Author】 Ma Lin,Li Yongjun,He Xun,Lan Yanyu,Wang Aimin,Wang Yonglin(Guiyang Medical College,Guiyang,Guizhou,China 550004)
【机构】 贵阳医学院; 贵阳医学院 贵州贵阳550004; 贵州贵阳550004;
【摘要】 目的建立辛芍注射液的含量测定方法。方法采用Diamonsil C18柱(250mm×4.6mm,5μm),以甲醇-0.1%甲酸溶液(40∶60)为流动相,流速1.0mL/min,检测波长230nm,柱温40℃。结果芍药苷质量浓度的线性范围为49~173μg/mL,r=0.9999,平均回收率为98.44%,RSD=2.0%(n=6)。结论所用方法简单、准确、重现性好,适用于辛芍注射液的质量控制。 更多还原
【Abstract】 Objective To establish a method for determining paeoniflorin in Xinshao Injection.Methods Diamonsil C18 column(250 mm× 4.6 mm,5 μ m) was used with mixture of methanol-0.1% formic acid(40 ∶ 60) as the mobile phase and the flow rate of 1.0 mL/min.The detection wavelength was 230 nm and the temperature of column was 40 ℃.Results The linear range of paeoniflorin was 49-173 μ g/mL(r=0.999 9).The average recovery rate was 98.44% and RSD was 2.0%(n=6).Conclusion The method is simple,accurate,reproducib... 更多还原
【关键词】 辛芍注射液; 赤芍; 芍药苷; 高效
液相色谱法;
【Key words】 Xinshao Injection; Radix Paeoniae Rubra; paeoniflorin; HPLC;
【基金】 贵州省中药现代化科技产业研究开发专项基金项目,项目编号:黔科合农字[2006]5003。
