【作者】 刘俊达; 胡昌江; 李兴华;
【Author】 Liu Junda1,Hu Changjiang2,Li Xinghua2 (1.College of Materials and Chemistry and Chemical Engineering,Chengdu University of Technology,Chengdu,Sichuan,China 610059; 2.College of Pharmacy,Chengdu University of TCM,Chengdu,Sichuan,China 610075)
【机构】 成都理工大学材料与化学化工学院; 成都中医药大学药学院; 成都中医药大学药学院 四川成都610059; 四川成都610075;
【摘要】 目的建立理中汤配方颗粒中人参皂苷的含量测定方法。方法采用高效
液相色谱(HPLC)法,以Diamonsil-C18柱(150mm×4.6mm,5μm)为分析柱,流动相为乙腈-0.05%磷酸溶液(99∶400),检测波长为203nm,流速为1.00mL/min,柱温为25℃。结果进样量线性范围人参皂苷Rg1为0.992~6.944μg(r=0.9999),人参皂苷Re为0.8192~5.7344μg(r=0.9998)。人参皂苷Rg1平均回收率为97.24%,RSD为1.33%(n=9);人参皂苷Re平均回收率为97.21%,RSD为1.16%(n=9)。结论该方法可靠、准确、简便。 更多还原
【Abstract】 Objective To establish the determination method of ginsenoside content in Lizhongtang compatible granule.Methods The Diamonsil-C18 column (150 mm× 4.6 mm,5 μ m) was used.The mobile phase was acetonitrile-0.05% phosphoric acid (99 ∶ 400) and the detecting wavelength was at 203 nm.The flow rate was 1.00 mL/min and the column temperature was 25℃ .Results The linear range of ginsenoside Rg1 content determination was 0.992-6.944 μ g,r=0.999 9.The linear range of ginsenoside Re content determination w... 更多还原
【关键词】 理中汤配方颗粒; 人参皂苷; 高效
液相色谱法; 含量测定;
【Key words】 Lizhongtang compatible granule; ginsenoside; HPLC; content determination;
【基金】 国家“十五”重大科技专项,项目编号:2001BA701A40-1
