【作者】 胡昌江; 李兴华; 杨婷; 吴平; 李兴迎;
【Author】 Hu Changjiang,Li Xinghua,Yang Ting,Wu Ping,Li Xingying(Pharmacy College,Chengdu University of TCM,Chengdu,Sichuan,China 610075)
【机构】 成都中医药大学药学院; 成都中医药大学药学院 四川成都610075; 四川成都610075;
【摘要】 目的建立理中汤配方颗粒中甘草酸的含量测定方法。方法采用高效
液相色谱法(HPLC法),以Diamonsil-C18柱(150mm×4.6mm,5μm)为分析柱,流动相为甲醇-0.2mol/L醋酸铵溶液-冰醋酸(67∶33∶1),检测波长为250nm,流速为1.00mL/min,柱温为40℃。结果甘草酸进样量在0.5736~4.0152μg范围内与峰面积呈良好线性关系,r=0.9998;平均回收率为99.12%,RSD=1.19%(n=9)。结论该方法可靠、准确、简便。 更多还原
【Abstract】 Objective To establish the determination method of glycyrrhizic acid content in Lizhongtang compatible granule.Methods The Diamonsil-C18(150 mm×4.6 mm,5 μm) column was used.The mobile phase was CH3OH-0.2 mol/L CH3COONH4-CH3COOH(67 ∶33 ∶1) and the detecting wavelength at 250 nm.The flow rate was 1.00 mL/min and the column temperature was 40℃.Results The linear range of glycyrrhizic acid content determination was 0.573 6~4.015 2 μg,r=0.999 8.The average recovery was 99.12%,RSD=1.19%(n=9). Conclusi... 更多还原
【关键词】 理中汤配方颗粒; 甘草酸; 高效
液相色谱法; 含量测定;
【Key words】 Lizhongtang compatible granule; glycyrrhizic acid; HPLC; content determination;
【基金】 国家“十五”重大科技专项,项目编号:2001BA701A40-1。
