主题:【分享】光学显微镜基础知识100条 读完你就成显微镜专家了
浏览0 回复12 电梯直达
省部重点实验室
1显微镜的光学原理图 ................................................................................................................... 1
2显微镜观察方式一 明视野观察(Bright field, BF) .............................................................. 1
3显微镜观察方式二 暗视野观察(Dark field) ....................................................................... 1
4显微镜观察方式三 相差镜检法(Phase contrast, PH) ...................................................... 2
5显微镜观察方式四 微分干涉镜检术(DIC) ......................................................................... 3
6显微镜观察方式五 偏光显微镜(Polarizing Microscopy, POL) ....................................... 4
7显微镜观察方式六 霍夫曼调制相衬(HMC) ....................................................................... 5
8显微镜观察方式七 荧光显微镜(Fluorescence Microscopy, FL) .................................... 6
9显微镜观察方式八 塑料DIC(Plas DIC) ............................................................................ 7
10物镜 ............................................................................................................................................ 7
11消色差物镜(Achromatic) ...................................................................................................... 8
12复消色差物镜(Apochromatic) ............................................................................................. 8
13平场消色差物镜(Plana chromatic) ..................................................................................... 8
14平场复消色差物镜(PF, Planapochromatic) ....................................................................... 8
15半复消色差物镜(Semi Apochromatic) ............................................................................... 8
16放大率(Magnification) .......................................................................................................... 8
17视场数 ........................................................................................................................................ 9
18物镜参数:数值孔径 ................................................................................................................. 9
19物镜参数:焦深 ....................................................................................................................... 10
20物镜参数:齐焦距离 ............................................................................................................... 10
21物镜参数:工作距离 ............................................................................................................... 11
22物镜参数:分辨率 ................................................................................................................... 11
23覆盖差 ...................................................................................................................................... 11
24齐焦合轴 ..................................................................................................................................
该帖子作者被版主 zhang88268572积分, 2经验,加分理由:鼓励分享
您可能想找: 生物显微镜 询底价
xiangboys
m3112470
0916257
黑侠2009
Insp_6dd79d5c
巨璟仪器
panda2011
iuugee
BGFLASER
TPTET
怎么才可以看到呢?想学习一下
我们也是做显微镜物镜的,www.tptet.com, 正是我们需要的知识,感谢楼主
