本实验室7300DV型ICP-OES点炬总是失败,给出的错误提示为下图:
查看仪器的“黑匣子”,生成的记录如下
Generator32 BlackBoxLogEntry,Date,Time,Ids1,Ids2,Vout,Power,Sample Compart,Neb FlowSense,Aux Flow Sense,Plasma Flow Sense,Drain Cap Relay,Heat SinkTemp,Electronics Temp,Neb Pressure Sense,+24V Supply,Ignitor,EMO Latch,DoorSwitch,Torch Switch,EMO Switch,Water Flow,Shear Flow,Sample,Plasma Detect,AuxFlow Control,Plasma Flow Control,Neb Flow Control,Bias Control,ProgramVoltage,Diode Limit1,09/25/13,09:51:00.86,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.002,09/25/13,09:51:00.87,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.003,09/25/13,09:51:00.88,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.004,09/25/13,09:51:00.89,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.005,09/25/13,09:51:00.90,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.006,09/25/13,09:51:00.91,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.007,09/25/13,09:51:00.92,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.008,09/25/13,09:51:00.93,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.009,09/25/13,09:51:00.94,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0010,09/25/13,09:51:00.95,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0011,09/25/13,09:51:00.96,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0012,09/25/13,09:51:00.97,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0013,09/25/13,09:51:00.98,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0014,09/25/13,09:51:00.99,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0015,09/25/13,09:51:00.00,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0016,09/25/13,09:51:00.01,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0017,09/25/13,09:51:00.02,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0018,09/25/13,09:51:00.03,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0019,09/25/13,09:51:00.04,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0020,09/25/13,09:51:00.05,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0021,09/25/13,09:51:00.06,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0022,09/25/13,09:51:00.07,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0023,09/25/13,09:51:00.08,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0024,09/25/13,09:51:00.09,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0025,09/25/13,09:51:00.10,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0026,09/25/13,09:51:00.11,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0027,09/25/13,09:51:00.12,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0028,09/25/13,09:51:00.13,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0029,09/25/13,09:51:00.14,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0030,09/25/13,09:51:00.15,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0031,09/25/13,09:51:00.16,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0032,09/25/13,09:51:00.17,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0033,09/25/13,09:51:00.18,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0034,09/25/13,09:51:00.19,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0035,09/25/13,09:51:00.20,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0036,09/25/13,09:51:00.21,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0037,09/25/13,09:51:00.22,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0038,09/25/13,09:51:00.23,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0039,09/25/13,09:51:00.24,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0040,09/25/13,09:51:00.25,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,NO,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0041,09/25/13,09:51:00.26,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0042,09/25/13,09:51:00.27,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0043,09/25/13,09:51:00.28,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0044,09/25/13,09:51:00.29,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0045,09/25/13,09:51:00.30,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0046,09/25/13,09:51:00.31,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0047,09/25/13,09:51:00.32,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0048,09/25/13,09:51:00.33,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0049,09/25/13,09:51:00.34,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0050,09/25/13,09:51:00.35,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0051,09/25/13,09:51:00.36,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0052,09/25/13,09:51:00.37,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0053,09/25/13,09:51:00.38,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0054,09/25/13,09:51:00.39,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0055,09/25/13,09:51:00.40,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0056,09/25/13,09:51:00.41,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0057,09/25/13,09:51:00.42,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0058,09/25/13,09:51:00.43,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0059,09/25/13,09:51:00.44,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0060,09/25/13,09:51:00.45,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0061,09/25/13,09:51:00.46,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,15.00, 0.0062,09/25/13,09:51:00.47,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,16.00, 0.0063,09/25/13,09:51:00.48,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,16.00, 0.0064,09/25/13,09:51:00.49,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,17.00, 0.0065,09/25/13,09:51:00.50,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,17.00, 0.0066,09/25/13,09:51:00.51,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,18.00, 0.0067,09/25/13,09:51:00.52,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,19.00, 0.0068,09/25/13,09:51:00.53,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,19.00, 0.0069,09/25/13,09:51:00.54,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,20.00, 0.0070,09/25/13,09:51:00.55,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,20.00, 0.0071,09/25/13,09:51:00.56,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,21.00, 0.0072,09/25/13,09:51:00.57,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,21.00, 0.0073,09/25/13,09:51:00.58,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,22.00, 0.0074,09/25/13,09:51:00.59,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,22.00, 0.0075,09/25/13,09:51:00.60,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,23.00, 0.0076,09/25/13,09:51:00.61,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,23.00, 0.0077,09/25/13,09:51:00.62,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,24.00, 0.0078,09/25/13,09:51:01.64,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,25.00, 0.0079,09/25/13,09:51:01.64,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,25.00, 0.0080,09/25/13,09:51:01.65,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,26.00, 0.0081,09/25/13,09:51:01.66,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,26.00, 0.0082,09/25/13,09:51:01.67,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,27.00, 0.0083,09/25/13,09:51:01.68,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,27.00, 0.0084,09/25/13,09:51:01.69,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,28.00, 0.0085,09/25/13,09:51:01.70,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,28.00, 0.0086,09/25/13,09:51:01.71,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,29.00, 0.0087,09/25/13,09:51:01.72,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,29.00, 0.0088,09/25/13,09:51:01.73,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,30.00, 0.0089,09/25/13,09:51:01.74,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,31.00, 0.0090,09/25/13,09:51:01.75,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,31.00, 0.0091,09/25/13,09:51:01.76,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,32.00, 0.0092,09/25/13,09:51:01.77,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,32.00, 0.0093,09/25/13,09:51:01.78,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,33.00, 0.0094,09/25/13,09:51:01.79,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,33.00, 0.0095,09/25/13,09:51:01.80,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,34.00, 0.0096,09/25/13,09:51:01.81,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,34.00, 0.0097,09/25/13,09:51:01.82,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,35.00, 0.0098,09/25/13,09:51:01.84,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.0099,09/25/13,09:51:01.85,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00100,09/25/13,09:51:01.86,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00101,09/25/13,09:51:01.87,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00102,09/25/13,09:51:01.88,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00103,09/25/13,09:51:01.89,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00104,09/25/13,09:51:01.90,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00105,09/25/13,09:51:01.91,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00106,09/25/13,09:51:01.92,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00107,09/25/13,09:51:01.93,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00108,09/25/13,09:51:01.94,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00109,09/25/13,09:51:01.95,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00110,09/25/13,09:51:01.96,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00111,09/25/13,09:51:01.97,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00112,09/25/13,09:51:01.98,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00113,09/25/13,09:51:01.99,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00114,09/25/13,09:51:01.00,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00115,09/25/13,09:51:01.01,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00116,09/25/13,09:51:01.02,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00117,09/25/13,09:51:01.03,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00118,09/25/13,09:51:01.04,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00119,09/25/13,09:51:01.05,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00120,09/25/13,09:51:01.06,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00121,09/25/13,09:51:01.07,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00122,09/25/13,09:51:01.08,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00123,09/25/13,09:51:01.09,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00124,09/25/13,09:51:01.10,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00125,09/25/13,09:51:01.11,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00126,09/25/13,09:51:01.12,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00127,09/25/13,09:51:01.13,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00128,09/25/13,09:51:01.14,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00129,09/25/13,09:51:01.15,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00130,09/25/13,09:51:01.16,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00131,09/25/13,09:51:01.17,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00132,09/25/13,09:51:01.18,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00133,09/25/13,09:51:01.19,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00134,09/25/13,09:51:01.20,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00135,09/25/13,09:51:01.21,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00136,09/25/13,09:51:01.22,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00137,09/25/13,09:51:01.23,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00138,09/25/13,09:51:01.24,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00139,09/25/13,09:51:01.25,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00140,09/25/13,09:51:01.26,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00141,09/25/13,09:51:01.27,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00142,09/25/13,09:51:01.28,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00143,09/25/13,09:51:01.29,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00144,09/25/13,09:51:01.30,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00145,09/25/13,09:51:01.31,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00146,09/25/13,09:51:01.32,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00147,09/25/13,09:51:01.33,0.0, 0.0, 0.01,0, 6.0, 0.09,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00148,09/25/13,09:51:01.34,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00149,09/25/13,09:51:01.35,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00150,09/25/13,09:51:01.36,0.0, 0.0, 0.01,0, 6.0, 0.10,0.2,10,OFF,26.5,33.0,0,23,OFF,OFF,CLOSED,NO,NO,YES,NO,NO,OFF,0.2,10,0.00,0.00,36.00, 0.00””
各位觉得从什么方面去维修呢,说说自己的看法吧!
