主题:HSCCC与HPLC在指纹图谱上的对比研究
浏览0 回复0 电梯直达
tauto
Comparison of high-speed counter-current chromatography and high-performance liquid chromatography on fingerprinting of
Chinese traditional medicine
Ming Gu∗, Fan Ouyang, Zhiguo Su
National Key Laboratory of Biochemical Engineering, Institute of Process Engineering,
Chinese Academy of Sciences, Beijing, China
Received 28 April 2003; received in revised form 10 September 2003; accepted 19 September 2003
Abstract
Active constituents of Chinese traditional medicine (CTM) are influenced by soils, climates, and growth stages. Therefore, fingerprint is important in quality control of CTM. Our studies showed for the first time that high-speed counter-current chromatography (HSCCC) could be applied in the development of fingerprint of CTM. Twelve components were separated from extracts of three crude samples of Salvia
miltiorrhiza Bunge, which were collected from different growth locations. All 12 components of each sample were isolated within 13 h coming with good correspondence by using HSCCC. Relative standard deviation (R.S.D.) values of the retention time in HSCCC separation was less than 3% satisfied the precision requirements of national standards in the fingerprint development. As a new approach, HSCCC was compared to the conventional approach-HPLC in our experiments. The fingerprint developed by HPLC comprised 11 peaks that collected within 45 min.R.S.D. values of retention times of the corresponding peaks in HPLC analysis were very small (maximum 0.66% and average 0.10%). In conclusion, HSCCC was a feasible method to be used in the development of fingerprint of CTM.
1. Introduction
Secondary metabolites depending on growing circumstances
usually are active constituents of CTM. As a
result, a CTM may have variable chemical components
and contents according to the different soils and climates
that growing in as well as growth stages when being
harvested [1]. It is absolutely necessary to develop analytic
methods of CTM for quality control. Among all the
quality control systems, fingerprint has gained more and
more attention recently after it is applied widely in quality
control of CTM [2]. Fingerprint is a kind of method
to show chemical information of medicines with chromatograms,
spectrograms and other graphs by chemical
analytical techniques. The major feature of fingerprints is
commonness of the same kind of medicine from different
collections.
您可能想找: 液相色谱(LC) 询底价
