来自:
http://bbs.bio668.com/read.php?tid-167-fpage-3.html
仪器中文名称 仪器英文名称 英文缩写
原子发射光谱仪 Atomic Emission Spectrometer AES
电感偶合等离子体发射光谱仪 Inductive Coupled Plasma Emission Spectrometer ICP
直流等离子体发射光谱仪 Direct Current Plasma Emission Spectrometer DCP
紫外-可见光分光光度计 UV-Visible Spectrophotometer UV-Vis
微波等离子体光谱仪 Microwave Inductive Plasma Emission Spectrometer MIP
原子吸收光谱仪 Atomic Absorption Spectroscopy
AAS 原子荧光光谱仪 Atomic Fluorescence Spectroscopy AFS
傅里叶变换红外光谱仪 FT-IR Spectrometer FTIR
傅里叶变换拉曼光谱仪 FT-Raman Spectrometer FTIR-Raman
气相色谱仪 Gas Chromatograph
gc 高压/效
液相色谱仪 High Pressure/Performance Liquid Chromatography HPLC
离子色谱仪 Ion Chromatograph
凝胶渗透色谱仪 Gel Permeation Chromatograph GPC
体积排阻色谱 Size Exclusion Chromatograph SEC
X射线荧光光谱仪 X-Ray Fluorescence Spectrometer XRF
X射线衍射仪 X-Ray Diffractomer XRD
同位素X荧光光谱仪 Isotope X-Ray Fluorescence Spectrometer
电子能谱仪 Electron Energy Disperse Spectroscopy
能谱仪 Energy Disperse Spectroscopy EDS
质谱仪 Mass Spectrometer MS
ICP-质谱联用仪
ICP-MS ICP-MS 气相色谱-质谱联用仪
gc-MS
gc-MS
液相色谱-质谱联用仪 LC-MS LC-MS
核磁共振波谱仪 Nuclear Magnetic Resonance Spectrometer NMR
电子顺磁共振波谱仪 Electron Paramagnetic Resonance Spectrometer ESR
极谱仪 Polarograph
伏安仪 Voltammerter
自动滴定仪 Automatic Titrator
电导仪 Conductivity Meter
pH计 pH Meter
水质分析仪 Water Test Kits
电泳仪 Electrophoresis System
表面科学 Surface Science
电子显微镜 Electro Microscopy
光学显微镜 Optical Microscopy
金相显微镜 Metallurgical Microscopy
扫描探针显微镜 Scanning Probe Microscopy
表面分析仪 Surface Analyzer
无损检测仪 Instrument for Nondestructive Testing
物性分析 Physical Property Analysis
热分析仪 Thermal Analyzer
粘度计 Viscometer
流变仪 Rheometer
粒度分析仪 Particle Size Analyzer
热物理性能测定仪 Thermal Physical Property Tester
电性能测定仪 Electrical Property Tester
光学性能测定仪 Optical Property Tester
机械性能测定仪 Mechanical Property Tester
燃烧性能测定仪 Combustion Property Tester
老化性能测定仪 Aging Property Tester
生物技术分析 Biochemical analysis
PCR仪 Instrument for Polymerase Chain Reaction
PCR DNA及蛋白质的测序和合成仪 Sequencers and Synthesizers for DNA and Protein
传感器 Sensors
其他 Other/Miscellaneous
流动分析与过程分析 Flow Analytical and Process Analytical Chemistry
气体分析 Gas Analysis
基本物理量测定 Basic Physics
样品处理 Sample Handling
金属/材料元素分析仪 Metal/material elemental analysis
环境成分分析仪 CHN Analysis
发酵罐 Fermenter
生物反应器 Bio-reactor
摇床 Shaker
离心机 Centrifuge
超声破碎仪 Ultrasonic Cell Disruptor
超低温冰箱 Ultra-low Temperature Freezer
恒温循环泵 Constant Temperature Circulator
超滤器 Ultrahigh Purity Filter
冻干机 Freeze Drying Equipment
部分收集器 Fraction Collector
氨基酸测序仪 Protein Sequencer
氨基酸组成分析仪 Amino Acid Analyzer
多肽合成仪 Peptide synthesizer
DNA测序仪 DNA Sequencers
DNA合成仪 DNA synthesizer
紫外观察灯 Ultraviolet Lamp
分子杂交仪 Hybridization Oven
PCR仪
PCR Amplifier
化学发光仪 Chemiluminescence Apparatus
紫外检测仪 Ultraviolet Detector
电泳 Electrophoresis
酶标仪 ELIASA
CO2培养箱 CO2 Incubators
倒置显微镜 Inverted Microscope
超净工作台 Bechtop
流式细胞仪 Flow Cytometer
微生物自动分析系统 Automatic Analyzer for Microbes
生化分析仪 Biochemical Analyzer
血气分析仪 Blood-gas Analyzer
电解质分析仪 Electrolytic Analyzer
尿液分析仪 Urine Analyzer
临床药物浓度仪 Analyzer for Clinic Medicine Concentration
血球计数器 Hematocyte Counter
