序号 | 名称 | 数量 |
4-1 | Sep-pak Vac CarbonNH2 6cc 500mg ea 30/bx Sep-pak Vac 小柱,CarbonNH2,6cc/500 mg,30/盒 | 1 |
4-2 | Sep-pak Vac Flor 6cc 1g ea 30/bx CERT Sep-pak 经认证,Florisil 6cc/1g,30/盒 | 20 |
4-3 | Sep-pak Vac NH2 6cc 500mg 30/bx Sep-pak Vac 小柱,NH2,6cc/500 mg,30/盒 | 20 |
4-4 | DisQuE Dispersive Sample Preparation Kit Includes: DisQuE试剂盒(AOAC法)包含: 15×186004571 DisQuE 50ml Tube/AOAC-Acetate DisQuE 500ml 提取管(AOAC法/醋酸盐) 15×186004572 DisQuE 2ml Tube/AOAC DisQuE 500ml 净化管-AOAC法 | 15 |
4-5 | ACQUITY UPLC HSS T3 1.8um 2.1×100mm ACQUITY 色谱柱, HSS T3 1.8um 2.1×100mm | 1 |
4-6 | CORTECS UPLC C18+ 1.6u 2.1×100mm Column | 1 |
4-7 | CORTECS UPLC C18 1.6u 2.1×100mm 3-pk Includes: CORTECS UPLC C18 1.6u 2.1×100mm 3-pk 包含: 3×186007095 CORTECS UPLC C18 1.6u 2.1×100mm Column | 1 |
4-8 | Kit,ACQUITY COL.In-Line Filter ACQUITY 在线色谱柱过滤器组件 | 1 |
4-9 | CAPILLARY TUBE(2pk) ESI不锈钢毛细管(2pk) | 1 |
4-10 | HYDROCRACKED MINERAL OIL WITH ADDITIVES 初级真空机械泵油1升(加氢裂化矿物油) | 1 |
4-11 | 700004485机械泵油(1L) | 1 |
4-12 | PEEK TUBING,005×1/16〝×60〞 PEEK 管,005×1/16〝×60〞 | 1 |
4-13 | FITTING,10-32,ONE-PIECE,MODIFIED 10PK PEEK 接头(Acquity 柱温箱),黑色,10个/包 | 1 |
4-14 | PEEK UNION 1/16 WO NUT&FER | 1 |
4-15 | ACQUITY UPLC BEH HILIC 1.7um 2.1×100mm ACQUITY 色谱柱,BEH HILIC 1.7um 2.1×100mm | 1 |
