主题:【讨论】欧洲-FCM-橄榄油替代测试是否不合规?
浏览0 回复4 电梯直达
没办法的办法
根据EU 10/2011第22章节过渡期的规定:
Article 22
Transitional provisions
1. Until 31 December 2012 the supporting documents referred to in Article 16 shall be based on the basic rules for overall and specific migration testing set out in the Annex to Directive 82/711/EEC.
2. As from 1 January 2013 the supporting documents referred to in Article 16 for materials, articles and substances placed on the market until 31 December 2015, may be based on:
(a) the rules for migration testing set out in Article 18 of this Regulation; or
(b) the basic rules for overall and specific migration testing set out in the Annex to Directive 82/711/EEC.
3. As from 1 January 2016, the supporting documents referred to in Article 16 shall be based on the rules for migration testing set out in Article 18, without prejudice to paragraph 2 of this Article.
4. Until 31 December 2015 additives used in glass fibre sizing for glass fibre reinforced plastics which are not listed in Annex I have to comply with the risk assessment provisions set out in Article 19.
第三段指出,自2016年1月1日起,不再承认82/711/EEC建立的迁移规则,而橄榄油的替代测试的规则正是82/711/EEC的内容。
这是不是意味着橄榄油的替代测试结果其实是不符合法规的?
该帖子作者被版主 一曝十寒2积分, 2经验,加分理由:有心人
pengwenqi
这还真是一个问题耶,但欧盟那些迁移的方法都是很久前的了,都在用,这个应该没出新的前还是有效的吧。
该帖子作者被版主 zwhyghl2积分, 2经验,加分理由:参与讨论
没办法的办法
原文由 pengwenqi(pengwenqi) 发表:
可是如果有人或者客户深究这个问题呢?其实欧盟是有橄榄油的测试方法的。EN1186里面就有,只是方法非常繁琐,而且复杂,也有很多不可控的技术因素。
该帖子作者被版主 zwhyghl2积分, 2经验,加分理由:说的很中肯
一曝十寒
原文由 没办法的办法(v2671144) 发表:
该把这方法重新练练熟练了!
seaandy1219
其实是使用橄榄油浸泡是测试周期不可控,测试的步骤增多,实验室成本翻了很多倍,除非客户特别要求,一般不愿意使用,方法一直是有的。而且现行的SN/T 2817和2735讲的测试步骤是和EN1186几乎一致的。
