主题:【讨论】数据软件咨询
浏览0 回复11 电梯直达
feiniao
数据软件有谁知道吗,能介绍一下吗?
该帖子作者被版主 symmacros3积分, 2经验,加分理由:发帖。
风痕
gerstel家的?
  嗅闻检测口你那边是不是有?我上次帖子里的问题,你有没有啥看法?指点一下。
symmacros
It is an integrated software
approach for simultaneous processing of both retention
index (RI) and mass spectral (MS) data for rapid and
improved identification of flavor compounds. The program
can be integrated into Agilent Chemstation Software and
searches are performed using CAS numbers of candidate
compounds after library searching and corresponding
automatically generated RI values. When MS signals are
too weak to be used the software allows two RI values from
orthogonal columns (after gc-O organoleptic evaluation) to
be cross searched in the database. This offers a very useful
additional identification procedure for flavor compounds.
The searchable database comprises > 10,000 compounds and
offers the practicing analyst full results oriented software
manipulation of RI and MS data on flavor compounds.
2016/7/24 12:37:22 Last edit by jimzhu
feiniao
原文由 symmacros(jimzhu) 发表:
Aroma Office 2D (Gerstel K.K.) is an integrated software
朱工 你们公司有这个吗?有网址吗?
symmacros
小川公司有,我们没有,但我们的比这个要好得多。
symmacros
AromaOffi ce: Application of a Novel
Linear Retention Indices Database to a
Complex Hop Essential Oil
2016/7/22 22:11:09 Last edit by jimzhu
sallysally
symmacros
风痕
原文由 symmacros(jimzhu)发表:小川公司有,我们没有,但我们的比这个要好得多。
能透露一下名称吗?
symmacros
原文由 风痕(yiwang520) 发表:
能透露一下名称吗?
我们是自己编写的软件。
风痕
我们是自己编写的软件。
好厉害。既要懂仪器,又要懂编程。
手机版: 数据软件咨询
