9.4.2 If a standard or specification for use between two or three parties requires a defined property level after a specific time or radiant exposure in an exposure test conducted according to this practice, base the specified property level on at least two independent experiments run in each laboratory to determine the reproducibility for the exposure and property measurement process. The reproducibility of the exposure/property measurement process is then used to determine the maximum or minimum level of property after the exposure that is mutually agreeable to all parties.
9.4.3 When reproducibility in results from an exposure test conducted according to this practice has not been established through round-robin testing, specify performance requirements for materials in terms of comparison (ranked) to a control material. All specimens shall be exposed simultaneously in the same device. All concerned parties must agree on the specific control material used.
9.4.3.1 Conduct analysis of variance to determine whether the differences between test materials and any control materials used are statistically significant. Expose replicates of the test specimen and the control specimen so that statistically significant performance differences can be determined.
