原文由 beastwo 发表:
Check Valve Cartridge Assembly,1090 止回阀滤芯气门组件,1090
Sapphire Piston,1090 宝石活塞,1090
Piston Seals,Black,1090,4/pk 活塞密封圈,黑色,1090,4/pk
Replacement Sieve 往复过滤筛
Wash Seal 冲洗密封圈
Needle Seat Assembly 针座组件
Seal Wash Kit,Binary Pump(4 seals,4 gaskets)密封圈冲洗选件,二元泵(4 密封圈,4 垫圈)
Cartridge Check Valve,616(SST) 止回阀滤芯,616(SST)
帮我看下可以这样翻?东西太专业了有点吃不准!!!!!!
