互溶的溶剂
在用混合溶剂进行重结晶的时候,如果溶剂之间的互溶性不好,在加入不良溶剂的时候,溶液会分层,而样品会留在良溶剂中。
经常使用乙醇和水这个搭配,因为乙醇能溶解许多有机物,并且乙醇能与水无限混溶。在乙醇中加入水,可以急剧的降低许多有机物在乙醇中的溶解度,因此可以用来进行重结晶。当然,有机溶剂相互之间的搭配也是常使用的。
可以依据相似性原理来选择溶剂。含羟基的化合物,可以选择水,甲醇,乙醇,乙酸,丙酮为良溶剂。当然,良溶剂的相似性不能太高,否则重结晶损失较大。如果杂质的极性较小,就可以选择极性较小的不良溶剂,比如醚,烷烃类。
三组分以上的混合溶剂的选择余地更大,甲醇、异丙醚、石油醚,也可以搭配使用。
下面的列表摘自Purification of Purification of Laboratory Chemicals第四版,该列表没有提到乙酸乙酯和石油醚的互溶性,不过许多化合物,也是可以用这个搭配。
Acetic acid: with chloroform, ethanol, ethyl acetate, methyl cyanide, petroleum ether, or water.
Acetone: with benzene, butyl acetate, butyl alcohol, carbon tetrachloride, chloroform, cyclohexane, ethanol,
Ammonia: with ethanol, methanol, pyridine.
Aniline: with acetone, benzene, carbon tetrachloride, ethyl ether, n-heptane, methanol, methyl cyanide or
nitrobenzene.
Benzene: with acetone, butyl alcohol, carbon tetrachloride, chloroform, cyclohexane, ethanol, methyl
cyanide, petroleum ether or pyridine.
Butyl alcohol: with acetone or ethyl acetate.
Carbon disulphide: with petroleum ether.
Carbon tetrachloride: with cyclohexane.
Chloroform: with acetic acid, acetone, benzene, ethanol, ethyl acetate, hexane, methanol or pyridine.
Cyclohexane: with acetone, benzene, carbon tetrachloride, ethanol or ethyl ether.
Dimethyl formamide: with benzene, ethanol or ether.
Dimethyl sulphoxide: with acetone, benzene, chloroform, ethanol, ethyl ether or water.
Dioxane: with benzene, carbon tetrachloride, chloroform, ethanol, ethyl ether, pet. ether, pyridine or water.
Ethanol: with acetic acid, acetone, benzene, chloroform, cyclohexane, dioxane, ethyl ether, pentane, toluene, water or xylene.
Ethyl acetate: with acetic acid, acetone, butyl alcohol, chloroform, or methanol.
Ethyl ether: with acetone, cyclohexane, ethanol, methanol, methylal, methyl cyanide, pentane or pet.ether.
Glycerol: with ethanol, methanol or water.
Hexane: with benzene, chloroform or ethanol.
Methanol: with chloroform, ethyl ether, glycerol or water.
Methylal: with ethyl ether.
Methyl ethyl ketone: with acetic acid, benzene, ethanol or methanol.
Nitrobenzene: with aniline, methanol or methyl cyanide.
Pentane: with ethanol or ethyl ether.
Petroleum ether: with acetic acid, acetone, benzene, carbon disulphide or ethyl ether.
Phenol: with carbon tetrachloride, ethanol, ethyl ether or xylene.
Pyridine: with acetone, ammonia, benzene, chloroform, dioxane, petroleum ether, toluene or water.
Toluene: with ethanol, ethyl ether or pyridine.
Water: with acetic acid, acetone, ethanol, methanol, or pyridine.
Xylene: with ethanol or phenol.
ethyl acetate, methyl acetate, methyl cyanide, petroleum ether or water.
互溶表
