01A0006089
Method 1624: Volatile Organic Compounds by Isotope Dilution GCMA; and Method 1625: Semivolatile Organic Compounds by Isotope Dilution GCMS. Revision C, June 1989.
(NTIS / PB92-231976 or CD ROM or http://www.epa.gov/waterscience/methods/guide/methods.html)
01A0006125
Region 1 Laboratory Data Validation Functional Guidelines for Evaluating Environmental Analyses. Part I, July 1996, revised
December 1996. Part II, Volatile/Semivolatile Data Validation Functional Guidelines. December 1996.
(Region 1 Library / http://www.epa.gov/ne/oeme/index.html)
01A0006218
Guidance for Performing Tests on Dredged Material to be Disposed of in Open Waters. Prepared by EPA Region 1 and ACOE, New England Division and NMFS of FWS. May 15, 1989. (Region 1 Library)
01A0006252
Determination of Radon in Drinking Water by Liquid Scintillation Counting: Method 913.0. Draft, May 1991. (Region 1 Library)
01A0006379
A Method for Measuring Sediment Oxygen Demand Using a Bench Model Benthic Respirometer. Peter M. Nolan and Arthur F. Johnson, EPA Region 1, May 1979. (Region 1 Library / http://www.epa.gov/region01/info/testmethods/pdfs/SOD-01A0006379.pdf) (PDF, 6 pp., 165KB)
01A0006408
Draft Methodology for the Measurement of Airborne Asbestos by Electron Microscopy. July 1984. (Region 1 Library)
01A0006706
Determination of Chlorinated Dibenzo-p-dioxins and Dibenzofurans in Soils and Sediments by Gas Chromatography/Mass Spectrometry.
December 15, 1986. (Region 1 Library)
01A0006709
Method 282.3 The Determination of Tributyltin Chloride in Marine and Fresh Waters by Liquid-Solic Extraction (LSE) and Gas Chromatography with Electron-Capture Detection (GC/ECD). Version 1.0, October 1989.
(Region 1 Library / http://www.epa.gov/ne/info/testmethods/pdfs/282-3-01A0006709.pdf) (PDF, 41 pp., 3.56 MB)
01A0007115
The Protocol for Screening Soil and Sediment Samples for Asbestos Content used by the US Environmental Protection Agency,
Region 1 Laboratory. December 1997. (Region 1 Library / http://www.epa.gov/ne/info/testmethods/pdfs/asbestos-01A0007115.pdf) (PDF, 6 pp., 295KB)
01A0007292
ColiSure Medium: Presence/Absence Test Method for Detection and Identification of Coliform Bacteria and E. coli in Drinking Water.
Millipore. (Region 1 Library)
01A0007431
Region 1 Low Stress (low flow) Purging and Sampling Procedure for the Collection of Ground Water Samples from Monitoring Wells.
SOW # GT 0001, Revision 2, July 30, 1996. (Region 1 Library or http://www.epa.gov/ne/measure/well/wellmon.html)
01A0007540
Region 1, EPA-New England Standard Operating Procedure for Elemental Analysis Using the X-Met 920 Field X-Ray Fluorescence Analyzer. SOP # X-MET 920, October 1996. (Region 1 Library)
01A0007541
Region 1, EPA-New England Immunoassay Guidelines for Planning Environmental Projects. October 1996.
(Region 1 Library or http://www.epa.gov/ne/measure/ia/iaguide.html)
01A0007846
Method 1630: Methyl Mercury in Water by Distillation, Aqueous Ethylation, Purge and Trap, and CVAFS.
Draft, August 1998. (Region 1 Library)
01A0007861
Method 6020 CLP-M: Inductively Coupled Plasma-Mass Spectrometry. May 1990. (Region 1 Library)
01A0007878
Method 556 Determination of Carbonyl Compounds in Drinking Water by Pentafluorobenzylhydroxylamine Derivation and Capillary Gas Chromatography with Electron Capture Detention. Revision 1.0, June 1998. (http://www.epa.gov/OGWDW/methods/pdfs/met556_1.pdf) (PDF, 37 pp., 139KB)
01A0007909
Method 1001: Lead in Drinking Water by Differential Pulse Anodic Stripping Voltametry. August 1999.
PALINTEST LTD. (21 Kenton Lands Road, PO BOX 18395, Erlanger, KY 41018 (606) 341-7423)
01A0007986
Field and Laboratory Methods for Macroinvertebrate and Habitat assessment of Low Gradient, Nontidal Streams. July 1997.
(http://www.epa.gov/maia/pdf/MACS-FieldandLabMethods.pdf) (PDF, 49 pp., 509KB)
01A0008028
Method 515.4 - Determination of Chlorinated Acids in Drinking Water by Liquid-Liquid Microextraction Derivatization, and Fast Gas Chromatography with Electron Capture Detection. 2000. (NERL-Cincinnati)
01A0008123
EPA Region 1 Standard Operating Procedure for Head Space Screening for Volatile Organic Compounds in Aqueous, Soil and Drum Samples. March 1998. (Region 1 Library)
01A0008143
Draft Calibration of Field Instruments (temperature, pH, dissolved oxygen, conductivity/specific conductance, oxidation/reduction potential [ORP], and turbidity). EPA Region 1 SOP, June 3, 1998. (Region 1 Library / .wpd file)
01A0008190
EPA Method 501.1 (1979), 501.2 (1979), and 525 Rev 2.1 (1988).
(Region 1 Library; 501.2 also at NEPIS / http://nepis.epa.gov/EPA/html/Pubs/pubtitleOther.htm)
01A0008217
Technical Guidance for the Natural Attenuation Indicators: Methane, Ethane, and Ethene.
EPA Region 1, Revision 1, February 21, 2002. (http://www.epa.gov/ne/measure/Natatten.pdf) (PDF, 18 pp., 46.8KB)
01A0008260
Regional Implementation Manual for the Evaluation of Dredged Material Proposed for Disposal in New England Waters.
USACE, NE District & US EPA NE, 2004. (http://www.nae.usace.army.mil/reg/regionalimplementationmanual.pdf ) (PDF, 62 pp., 265KB)
