原文由 安平(byron1111) 发表:Evaluation of the content - containing interaction in cosmetic products using gas chromatography-mass spectrometry和Optimization of the method of the content-containing interaction evaluation for cosmetic products by gas chromatography - mass spectrometry
有上下文么?
原文由 启航2021(uil1010) 发表:谢谢,有道理。
字面含义,就是成分相互作用,成分间相互作用。
可以参考下面论文Evaluation of the content - containing interaction in cosmetic products using gas chromatography-mass spectrometry和Optimization of the method of the content-containing interaction evaluation for cosmetic products by gas chromatography - mass spectrometry
