The number of measured poins shall be at least 20 per molecular-mass decade of the calibration curve used 应该是 The number of measured points shall be at least 20 per molecular-mass decade of the calibration curve used?
原文由 lxdongzi2003 发表: The number of measured poins shall be at least 20 per molecular-mass decade of the calibration curve used 应该是 The number of measured points shall be at least 20 per molecular-mass decade of the calibration curve used?
原文由 wggg 发表: 各位老师:请问The number of measured points shall be at least 20 per molecular-mass decade of the calibration curve used中的molecular-mass decade是什么意思?谢谢!
前半句:The number of measured points shall be at least 20:测定点数不少于20个 后半句:per molecular-mass decade of the calibration curve used:在标准曲线用的每个摩尔质量组
