比如用 100ug/ml的标准品来配制。配单标的话,抽取0.1ml,加溶剂0.9ml(即定容到1ml);若配混标(比如5种标准品),每样抽取0.1ml,共0.5ml,加溶剂0.5ml(即定容到1ml)即可。比如用 100ug/ml的标准品来配制。配单标的话,抽取0.1ml,加溶剂0.9ml(即定容到1ml);若配混标(比如5种标准品),每样抽取0.1ml,共0.5ml,加溶剂0.5ml(即定容到1ml)即可。比如用 100ug/ml的标准品来配制。配单标的话,抽取0.1ml,加溶剂0.9ml(即定容到1ml);若配混标(比如5种标准品),每样抽取0.1ml,共0.5ml,加溶剂0.5ml(即定容到1ml)即可。比如用 100ug/ml的标准品来配制。配单标的话,抽取0.1ml,加溶剂0.9ml(即定容到1ml);若配混标(比如5种标准品),每样抽取0.1ml,共0.5ml,加溶剂0.5ml(即定容到1ml)即可。比如用 100ug/ml的标准品来配制。配单标的话,抽取0.1ml,加溶剂0.9ml(即定容到1ml);若配混标(比如5种标准品),每样抽取0.1ml,共0.5ml,加溶剂0.5ml(即定容到1ml)即可。比如用 100ug/ml的标准品来配制。配单标的话,抽取0.1ml,加溶剂0.9ml(即定容到1ml);若配混标(比如5种标准品),每样抽取0.1ml,共0.5ml,加溶剂0.5ml(即定容到1ml)即可。比如用 100ug/ml的标准品来配制。配单标的话,抽取0.1ml,加溶剂0.9ml(即定容到1ml);若配混标(比如5种标准品),每样抽取0.1ml,共0.5ml,加溶剂0.5ml(即定容到1ml)即可。比如用 100ug/ml的标准品来配制。配单标的话,抽取0.1ml,加溶剂0.9ml(即定容到1ml);若配混标(比如5种标准品),每样抽取0.1ml,共0.5ml,加溶剂0.5ml(即定容到1ml)即可。
