主题:【已应助】PE的ICPMS NexION350X KED模式测铬、砷、镉信号值漂移,砷和铬信号值很低
浏览0 回复5 电梯直达
Ins_c0678eb0
推荐答案:Ins_1f104bc9回复于2024/07/19
信号低是不是氦气流速太大了,灵敏度不够?RSD过高可能是开机后氦气模式老化不够呢?
您可能想找: ICP-MS电感耦合等离子体质谱 询底价
Ins_c0678eb0
 试样识别码采集时间Sc 45 (IS)
(每秒计数)
与上一数据比值Cr 52
(每秒计数)
与上一数据比值Ge 72 (IS)
(每秒计数)
与上一数据比值As 75
(每秒计数)
与上一数据比值Cd 111
(每秒计数)
与上一数据比值In 115 (IS)
(每秒计数)
与上一数据比值Pb 208
(每秒计数)
与上一数据比值Bi 209 (IS)
(每秒计数)
1黄瓜0.052024/7/12 11:19:41118611.41046.048372.8194.0166.049930.813210.1834673.7
2黄瓜0.052024/7/12 11:21:02122356.81.031131.01.0849092.21.01208.01.07156.00.9449232.80.9913527.41.02839301.4
3黄瓜0.052024/7/12 11:21:20118221.20.971103.00.9848986.81.00152.00.73154.00.9949022.21.0013660.51.01840374.8
4黄瓜0.052024/7/12 11:21:37120349.81.021082.00.9848802.21.00192.01.26174.01.1350046.61.0213766.61.01838167.6
5黄瓜0.052024/7/12 11:21:55300824.32.503391.43.1379311.61.63317.01.65199.01.1465731.81.3113982.81.02879513.5
6黄瓜0.052024/7/12 11:22:11298771.90.993593.51.0678293.00.99290.00.91186.00.9366308.21.0114319.21.02897767.1
7黄瓜0.052024/7/12 11:22:29278267.00.933031.30.8475277.80.96320.01.10195.01.0568373.11.0314443.31.01898016.1
8黄瓜0.052024/7/12 11:22:44120143.10.431108.00.3749324.00.66155.00.48177.00.9150440.20.7413272.20.92830717.8
9黄瓜0.052024/7/12 11:23:00118251.40.981145.01.0347508.90.96178.01.15153.00.8649833.90.9913448.31.01824734.6
10黄瓜0.052024/7/12 11:23:15290497.92.463295.42.8877587.11.63314.01.76193.01.2665287.21.3113978.81.04868804.1
11黄瓜0.052024/7/12 11:23:31288414.30.993436.41.0477294.51.00292.00.93201.01.0463503.00.9713937.81.00869516.5
12黄瓜0.052024/7/12 11:23:48255239.00.883170.40.9271848.20.93251.00.86204.01.0163028.70.9913833.70.99869331.8
13黄瓜0.052024/7/12 11:24:03115802.50.45998.00.3146710.20.65195.00.78159.00.7848229.30.7712939.90.94799091.1
14黄瓜0.052024/7/12 11:24:20112395.40.971047.01.0545384.00.97179.00.92153.00.9646934.70.9712722.70.98797166.9
15黄瓜0.052024/7/12 11:24:35265661.42.362842.32.7176938.61.70239.01.34164.01.0765082.31.3913612.51.07846478.8
16黄瓜0.052024/7/12 11:24:51290668.31.093233.41.1470754.80.92289.01.21175.01.0766494.31.0213735.61.01860201.2
17黄瓜0.052024/7/12 11:25:07111480.30.381116.00.3544371.80.63173.00.60173.00.9945783.20.6912496.50.91775623.2
18黄瓜0.052024/7/12 11:25:22108295.90.971026.00.9242767.90.96134.00.77148.00.8644316.00.9712466.41.00767586.1
19黄瓜0.052024/7/12 11:25:38253442.42.342562.22.5063605.31.49263.01.96177.01.2055757.61.2612782.71.03793550.7
20黄瓜0.052024/7/12 11:25:54279094.91.103127.31.2268490.81.08316.01.20171.00.9763230.31.1313292.21.04830563.2
21黄瓜0.052024/7/12 11:26:09116636.20.421188.00.3852880.70.77201.00.64167.00.9850956.70.8112706.60.96787047.3
标准偏差845001083140176217847258038192
平均值194448.822079.7160171.58231.05173.5756072.5113435.04835629.88
相对标准偏差0.430.520.230.270.100.150.040.05
Ins_c0678eb0
Sc和Cr波动比较大,但是这俩元素波动频率一致,所以Cr以Sc为内标时比较准确,As与Ge和In的波动频率不一致,所以As的强度净值很飘,无法测出标准检出限,  如何解决了
c0678eb0(Ins_c0678eb0) 发表:
 试样识别码采集时间Sc 45 (IS)
(每秒计数)
与上一数据比值Cr 52
(每秒计数)
与上一数据比值Ge 72 (IS)
(每秒计数)
与上一数据比值As 75
(每秒计数)
与上一数据比值Cd 111
(每秒计数)
与上一数据比值In 115 (IS)
(每秒计数)
与上一数据比值Pb 208
(每秒计数)
与上一数据比值Bi 209 (IS)
(每秒计数)
Ins_c0678eb0
信低质量数信号值漂移和信号值偏小是仪器的原因吗?
Ins_c0678eb0
Ins_1f104bc9
